No Air from Defrost Vents - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > No Air from Defrost Vents
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-21-2009, 01:44 PM   #1
D73
Hi Guys,
I drive a 99 Grand Cherokee Ltd. I fixed the heater blendoor a couple of months ago and everything worked ok but now i don`t get any air coming from the defrost vent to the windshield. all other vents seem to work fine and the blower motor is working. i am getting fault code 13 = Mode motor not responding.
i also noticed that i can`t set the climate controll to the hi or low automatic setting anymore. any ideas as i am driving around with fogged up windscreen.
Many thanks
Dirk
D73 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2009, 01:46 PM   #2
JeepPimp
do all of the speeds work for the fan control?
JeepPimp is offline   Reply With Quote Quick reply to this message
Unread 12-21-2009, 01:51 PM   #3
D73
all speeds work ok.
Unread 12-21-2009, 01:54 PM   #4
D73
it blows hot or cold through floor/dash etc. but nothing at all to the windscreen.
Unread 12-21-2009, 01:54 PM   #5
JeepPimp
you got more then 1 blower motor?
Unread 12-21-2009, 01:59 PM   #6
D73
i guess only one. i checked the connection to the blower motor and couldn`t find anything wrong.
Unread 12-21-2009, 02:03 PM   #7
D73
i checked the error codes and i get 13, 24, 48, 52 and 54. i guess the 52 and 54 are historic ones from the previous blend door problem. this is driving me mad as i am driving around with a damn cloth in my hand.
Unread 12-21-2009, 04:53 PM   #8
BigE3
could be a stuck actuator. I do believe the actuators had metal plungers to push the door. but if they changed it to plastic that year. it could be that the plastic piece rounded out and not letting the door close that far. The new peterbilt trucks use the same POS part and its more expensive at Peterbilt than it does at an auto store.
might sound stupid, but its a piece of info
I like my Jeep, just like my women. 'Loose and Flexible'
BigE3 is offline   Reply With Quote Quick reply to this message
Unread 01-04-2010, 09:54 AM   #9
mainfr4me
@D73
Were you able to resolve this?
mainfr4me is offline   Reply With Quote Quick reply to this message
Unread 01-04-2010, 01:11 PM   #10
D73
Hi mainfr4me
I checked the vacuum lines,connections. all seems ok. after going through some related posts i also checked the cruise control which is working. seems like all the other guys get it stuck on defrost. mine is the other way around.lol
I tried to access the actuator doors from under the dash but couldn`t get nowhere near it.
Still getting error code 13 = mode motor not responding.
Any help would be appreciatet as i am having a hard time driving around like this.
