Night Crew Questions!?? Thanks! - JeepForum.com
post #1 of 12 Old 08-19-2009, 10:20 PM Thread Starter
thaBrad
Asking ya'll owls to hopefully get answers quickly. Tomorrow I'm going to Colts preseason, 2nd row behind visitors bench! (Eagles with no Vick) So I wanna check some things before the 100 mile trek R.T.
I was straighting my steering wheel and checked my tracking. I'm off 1/4"-3/8". What causes that? It was dead on when I put the adj track on. Would it be the top CA on the pumpkin having alot of side to side play it looks like? The difference is to the right side! Picture below.
And I measured from inner tire to frame by sway links. Pic below.
Thirdly, I think I have a axle seal leak. Agreed?
Left Axle
Right Axle
Thanks guys! I'm passing out from long day & night! Greatly appreciated!!
3" IRO, Bilstein's, 32" KM's on 17" Soft 8's
thaBrad is offline
post #2 of 12 Old 08-19-2009, 10:44 PM
trailblaze
trailblaze's Avatar
nightcrew?? wha??
nice leaky axle!! those are fun to fix. i agree with your call on that one!
stupid question but was the jeep on the ground when you put the adj trac bar on?
Matt
trailblaze is offline
post #3 of 12 Old 08-19-2009, 10:51 PM
Redbob
Could you have overfilled the axle with lube?
That'll make a leak no matter how good your seals are.
Redbob is offline
post #4 of 12 Old 08-19-2009, 11:26 PM
SDT03GCOverland
2003 WJ
Hard to tell, exactly but is that upper trac-bar end centered in the mounting bracket (bushing in relation to the bolt going through it) in the first pic? It appears to be shifted outboard approximately 1/4-3/8 inch in relation to the bolt in that pic. I had a similar issue with mine. When I tightened mine, my kids had been playing with my torque wrench and I did not realize it was not tight enough. My axle shifted in similar fashion. I re-centered and re-torqued to spec and problem solved.
2003 Grand Cherokee Overland, 4 inch Rough Country Lift, upgraded to Rusty's Front Long Arm, JKS Adjustable Trac-Bar
SDT03GCOverland is offline
post #5 of 12 Old 08-19-2009, 11:29 PM
gatorayde
The control arm looks normal. Those are pretty bad axle seal leaks, I hope gear lube doesn't do any damage to tires And more reason to do a d44a swap
gatorayde is offline
post #6 of 12 Old 08-20-2009, 07:11 AM Thread Starter
thaBrad
Originally Posted by trailblaze View Post
nightcrew?? wha??
Yes the Jeep was on the ground, and axle centered when I put it on. But thats been almost 2 months ago and I've wheeled a few times since that.
thaBrad is offline
post #7 of 12 Old 08-20-2009, 07:59 AM
j.love
j.love's Avatar
1994 ZJ
Did your springs settle in and you lost a little lift? That will make the axle shift over a bit.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #8 of 12 Old 08-20-2009, 08:11 AM
tennesseewj
Originally Posted by thaBrad View Post
My driver side upper CA looks off-center like that too, I was wondering if that was normal.
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #9 of 12 Old 08-20-2009, 12:57 PM Thread Starter
thaBrad
I'm thinking I need to change it to the Johnny Joint bushing.
So I did it right though with having the Jeep on its tires and not in the air to do the track bar right?!
thaBrad is offline
post #10 of 12 Old 08-20-2009, 01:15 PM
318jeepcherokee
yep you need some axle seals, tho's axle seals are fun... i did them on my dads 01 WJ..
connor.
-1998 grand cherokee 5.9- custom intake, MTX sledge hammer sub with two JBL audio speakers in the rear doors and JVC deck, Westin safari bar with two 6' lights, Yakima load warrior with reverse lights, Hooker aero chamber muffler.
318jeepcherokee is offline
post #11 of 12 Old 08-20-2009, 01:20 PM
j.love
j.love's Avatar
1994 ZJ
Yep you did it right.
Did you take measurements of your lift, hub to fender, when you first installed it? I bet your springs have settled in and now your axle is off a bit.
David.
Joe Biden
j.love is offline
post #12 of 12 Old 08-24-2009, 08:42 AM Thread Starter
thaBrad
I measured tire to frame at top of tire where it was straight over to frame. Check it again this weekend and it was fine?!! I'll keep checking it?!! WTF
thaBrad is offline
What are you doing Friday night? nierace ZJ Grand Cherokee Forum 56 03-07-2007 08:09 PM
Night time fun... slick2570 ZJ Grand Cherokee Forum 7 12-28-2006 09:26 AM
Totaled the ZJ last night josephmartins ZJ Grand Cherokee Forum 46 12-19-2005 08:09 PM
The New WK Crew mr_user ZJ Grand Cherokee Forum 8 06-02-2005 10:48 AM
Guess I joined the "submarine" crew.. b1pig ZJ Grand Cherokee Forum 16 02-07-2005 02:44 PM
