nice decent hitch opinions? - JeepForum.com
post #1 of 9 Old 07-08-2011, 07:49 PM Thread Starter
lbgreenroom
ok so im looking for a hitch not to expensive as i wont really be pulling anything. just incase i need to sometime and i figured eh why not get one. any advice on a decent not too expensive say under $150 dollar hitch? btw this is for a 97 limited zj.
thanks!
lbgreenroom is offline
post #2 of 9 Old 07-08-2011, 08:11 PM
SAR-Swimmer
I'd give you mine, if you lived closer, but shipping would kill you.
The stock tow hitch that came with the ZJs would be your best bet, you could find one at an auto-wrecker fairly cheaply, I'd think.
Just remember, if you add a hitch, everyone and their dog will want you to tow something for them, so you'll want to make sure you set up proper trailer lights, and if you do tow much, you might want to invest in a transmission-cooler as well.
SAR-Swimmer is offline
post #3 of 9 Old 07-08-2011, 08:14 PM
PitchblakToxic7
Go to Home Depot and pick one up for $30 bucks, no need to spend $150 unless you actually tow something often.
Just a tip, don't leave it in, it will be stolen eventually.
Edit: Never mind, I think we're talking about something else hahah. Regardless, never tow anything 2000lbs or more very far without a transmission cooler. If you pick a cooler up, I still would never push the weight farther then 3500-3700lbs, 4000lbs for short distances. ZJ's not built for it.
PitchblakToxic7 is offline
post #4 of 9 Old 07-08-2011, 08:24 PM Thread Starter
lbgreenroom
thanks for the heads up ill check out hd. found a reese for 125 might get that if i dont find anything else.
post #5 of 9 Old 07-08-2011, 08:35 PM
blackzj
check craigslist
blackzj is offline
post #6 of 9 Old 07-08-2011, 10:44 PM
JeepOrvis97
JeepOrvis97's Avatar
I got a killer deal on mine, about $15 with tax for a genuine mopar hitch and wiring harness kit from the local pull-a-part. It was on a Jeep that must have been from the south too since it was completely rust free. If you have any pull-a-part type places around you I'd check them out. I've seen hitches on the ZJs almost every time I go.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #7 of 9 Old 07-10-2011, 10:20 AM
AAA
^^^^^ What he said. Go to a pick your part place. You can look around the get the style you want off another ZJ. Also get the wiring harness. Make sure you bring some penetrating oil and a heavy duty wrench, as those bolts may be very hard to get off.
AAA is offline
post #8 of 9 Old 07-10-2011, 10:29 AM
leadfootny
I have a uhaul one I got from a jy for $75. If you do any kind of wheeling make sure it is a hidden style as some are fully below the bumper. A 2-3 inch difference in clearance.
leadfootny is offline
post #9 of 9 Old 07-10-2011, 10:32 AM
AAA
I wheel quite often, and mine goes under my bumper, but I got it that way to protect the bumper. If I ever get a heavy duty rear bumper, then I'd want one built in, but I like mine under it with the stock bumper for protection. All depends on what you want it for.
AAA is offline
aftermarket hitch vs factory hitch dharmabum WJ Grand Cherokee Forum 21 08-29-2014 01:38 PM
Valley hitch vs. Mopar hitch.... webejpn01 WK Grand Cherokee & XK Commander Forum 2 11-10-2009 05:34 PM
installing hitch and hitch bezel alexsious ZJ Grand Cherokee Forum 2 06-22-2009 11:56 AM
Reese Hitch...sits too low??? need hitch pictures please! JackedUPzeejay ZJ Grand Cherokee Forum 19 12-25-2008 02:03 PM
Is this a decent deal/decent tires? John in MA ZJ Grand Cherokee Forum 5 01-04-2007 02:19 PM
