next big project - JeepForum.com
post #1 of 6 Old 01-05-2006, 08:26 PM Thread Starter
grandman17
next big project
just finished my axle swap and motor rebuild, before i did any of this i had a minor leak coming from the rear main seal, so i finsihed rebuilding the motor ect, put oil in it to drive around and test it out ( planning on driving to school tomorrow UNTIL>>) now the rear main seal is a steady pour instead of a very minor drip, so now i will learn how to take the transmission and trans case off of the motor backing and replace the seal. anybody have a better way of doing this or any tricks or tips would be greatly appreciated, and also any special tools i will NEED.
grandman17 is offline
post #2 of 6 Old 01-05-2006, 08:39 PM
joeyschribar
hey tonight i just removed my tranny/t case. A transmission jack is essential!!!!!
Jack your jeep up a few feet as well.
Ratchet with as many long extenstions as possible, to get at the hard to reach bolts on the transmission.
joeyschribar is offline
post #3 of 6 Old 01-05-2006, 08:39 PM
W4x4J
What year jeep and what size motor?
John
99 limited, all-time 4x4, 4.7L, 2in bb lift, upcountry springs with mx-6's, 265/75/16 BFG's
Jeeps rock!!!!!!!!!
Taupe Frost Metallic Club member #2
W4x4J is offline
post #4 of 6 Old 01-06-2006, 05:38 PM Thread Starter
grandman17
93 GC 4.0 full time AWD tranny
post #5 of 6 Old 01-06-2006, 07:33 PM
greasefingers
greasefingers's Avatar
1994 ZJ
On 4L engine, the rear mail oil seal is accessible by removing the oil pan. Fel-Pro pn# BS 40612. I have one collecting dust. I have been meaning to do this for a one year now.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 6 Old 01-06-2006, 08:11 PM
Meerkat
Not to be too nit-picky, but where I come from, an engine rebuild would include replacing all the seals, not to mention all the bearings, rings, gaskets, camshaft (maybe)...
Like Grease said, you can change the rear main oil seal by simply dropping the oil pan. You'll want to use a wooden dowel or similar to drive the old seal out. Don't use metal, you don't want to scratch the sealing surface. Beyond that, socket set and torque wrench are pretty much the only tools required for the job. Review the procedure in your Haynes manual. It's a very complete, and accurate, guide on this particular project.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
zj project mudder_317 ZJ Grand Cherokee Forum 30 03-25-2008 06:23 PM
New project nashmd454 ZJ Grand Cherokee Forum 13 01-12-2008 12:42 PM
Looking at a project '98 ZJ rayar3 ZJ Grand Cherokee Forum 2 11-30-2007 09:14 PM
next project? Derek33 ZJ Grand Cherokee Forum 4 10-24-2007 03:21 PM
just trying to sum up my project Derek33 ZJ Grand Cherokee Forum 1 05-16-2007 08:39 AM
