Newfie's favorite links list - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Newfie's favorite links list
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-30-2010, 08:44 AM   #1
newfieZJ
Power steering mod
http://westtexasoffroad.homestead.co...rsteering.html
Coolant senor fix
http://www.jeepforum.com/forum/f13/c...moval-1228233/
DIY wheel toe adjustment
dodgeforum.com/forum/dodge-cummins-diesel/132717-diy-front-toe-adjustment.html
Pinion bearing how to
http://www.jeepforum.com/forum/f9/ho...60-mph-328055/
Rear wiper repair
www.nagca.com/grandtech/rearwiperrepair.htm
Want a 5 speed ?
http://www.high-impact.net/transmiss...05_2l-5_9l.htm
Steer box adjustments
dodgeram.info/tsb/1997/19-10-97.htm
Plenum gasket test
dodgeram.info/tsb/2000/09-05-00.htm
Ignition System Cross Fire/Secondary Ignition Wire Induction
dodgeram.info/tsb/1998/18-48-98/18-48-98.htm
Viscous coupling replacement
http://www.masoncomputing.com/np249/
Tire size calculator
http://www.1010tires.com/Tools/Tire-Size-Calculator
Heated seat fix
http://www.jeepsunlimited.com/forums...d.php?t=374914
IAC and throttle body cleaning
http://www.jeepforum.com/forum/f13/h...ighlight=clean
5.9 coolant hose switch housing
http://www.steigerperformance.com/PRODUCTS/sp40001.html
Enjoy the links Got some useful links to add to the list , let's have em
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 10-30-2010, 09:08 AM   #2
needspeed
Thanks for the info, but the steering box adjustment link is the same as the transmission link. Just thought I would let you know, plus I waould like to have the steering link.
needspeed is offline   Reply With Quote Quick reply to this message
Unread 10-30-2010, 10:09 AM   #3
newfieZJ
fixed
Unread 11-27-2010, 05:26 AM   #4
newfieZJ
Bumped for an added link I have been searching for , thanks ZeeJay1997
Speed tweeks , some interesting stuff to read
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
And , some wiring help for your accessories
http://www.the12volt.com/installbay/...eard/Jeep.html
Unread 09-15-2013, 10:34 PM   #5
newfieZJ
Time to update this thread , bah , maybe a bump too
Dash lights flickering fixed
http://www.jeepforum.com/forum/f13/r...-heavy-702703/
Trans mount replacement
http://www.jeepforum.com/forum/f13/9...heavy-1587401/
How to change a control arm bushing
http://www.jeepforum.com/forum/f13/h...asily-1248532/
Trans line check valve removal
http://www.jeepforum.com/forum/f13/t...77/index2.html
A very useful thread when you have stalling issues
http://www.jeepforum.com/forum/f13/1...l#post14045654
Unread 09-16-2013, 12:24 PM   #6
Y0ungGunZJ
all the ones that are replaced with a click able word it is giving me issues with time warner cable it doesn't show the correct link location.
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline   Reply With Quote Quick reply to this message
Unread 09-16-2013, 12:59 PM   #7
newfieZJ
Thanks for the heads up
All links updated and functional
Unread 09-16-2013, 04:14 PM   #8
PolkaPower
Is this the link to the power steering you wanted to post? http://westtexasoffroad.homestead.co...rsteering.html
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 09-16-2013, 05:42 PM   #9
newfieZJ
Hopefully have it this time .
Unread 09-16-2013, 06:54 PM   #10
coralman
its the beam Jim
coralman's Avatar
Thanks for the include newfie.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 09-16-2013, 07:08 PM   #11
newfieZJ
No prob my friend . Thank you for your efforts and a good job
I gotta try to edit in some heading details for the added links later . Feel free to add links to this thread .
Unread 12-07-2014, 12:45 PM   #12
newfieZJ
ZJ brake upgrade links
http://mallcrawlin.com/forum/showthr...ion-parts-list
http://www.jeepforum.com/forum/f13/b...82/index3.html
http://www.jeepsunlimited.com/forums...ake-Conversion
Unread 12-07-2014, 02:37 PM   #13
durango-bob
Here's one that I use quite a bit. The Factory Service Manual:
http://www.jeep4x4center.com/knowled...anding+125x125
durango-bob is offline   Reply With Quote Quick reply to this message
