Newfie's favorite links list - JeepForum.com
post #1 of 13 Old 10-30-2010, 07:44 AM Thread Starter
newfieZJ
Power steering mod
http://westtexasoffroad.homestead.co...rsteering.html
Coolant senor fix
http://www.jeepforum.com/forum/f13/c...moval-1228233/
DIY wheel toe adjustment
dodgeforum.com/forum/dodge-cummins-diesel/132717-diy-front-toe-adjustment.html
Pinion bearing how to
http://www.jeepforum.com/forum/f9/ho...60-mph-328055/
Rear wiper repair
www.nagca.com/grandtech/rearwiperrepair.htm
Want a 5 speed ?
http://www.high-impact.net/transmiss...05_2l-5_9l.htm
Steer box adjustments
dodgeram.info/tsb/1997/19-10-97.htm
Plenum gasket test
dodgeram.info/tsb/2000/09-05-00.htm
Ignition System Cross Fire/Secondary Ignition Wire Induction
dodgeram.info/tsb/1998/18-48-98/18-48-98.htm
Viscous coupling replacement
http://www.masoncomputing.com/np249/
Tire size calculator
http://www.1010tires.com/Tools/Tire-Size-Calculator
Heated seat fix
http://www.jeepsunlimited.com/forums...d.php?t=374914
IAC and throttle body cleaning
http://www.jeepforum.com/forum/f13/h...ighlight=clean
5.9 coolant hose switch housing
http://www.steigerperformance.com/PRODUCTS/sp40001.html
Enjoy the links Got some useful links to add to the list , let's have em
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #2 of 13 Old 10-30-2010, 08:08 AM
needspeed
Thanks for the info, but the steering box adjustment link is the same as the transmission link. Just thought I would let you know, plus I waould like to have the steering link.
needspeed is offline
post #3 of 13 Old 10-30-2010, 09:09 AM Thread Starter
newfieZJ
fixed
newfieZJ is offline
post #4 of 13 Old 11-27-2010, 04:26 AM Thread Starter
newfieZJ
Bumped for an added link I have been searching for , thanks ZeeJay1997
Speed tweeks , some interesting stuff to read
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
And , some wiring help for your accessories
http://www.the12volt.com/installbay/...eard/Jeep.html
newfieZJ is offline
post #5 of 13 Old 09-15-2013, 09:34 PM Thread Starter
newfieZJ
Time to update this thread , bah , maybe a bump too
Dash lights flickering fixed
http://www.jeepforum.com/forum/f13/r...-heavy-702703/
Trans mount replacement
http://www.jeepforum.com/forum/f13/9...heavy-1587401/
How to change a control arm bushing
http://www.jeepforum.com/forum/f13/h...asily-1248532/
Trans line check valve removal
http://www.jeepforum.com/forum/f13/t...77/index2.html
A very useful thread when you have stalling issues
http://www.jeepforum.com/forum/f13/1...l#post14045654
newfieZJ is offline
post #6 of 13 Old 09-16-2013, 11:24 AM
Y0ungGunZJ
all the ones that are replaced with a click able word it is giving me issues with time warner cable it doesn't show the correct link location.
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #7 of 13 Old 09-16-2013, 11:59 AM Thread Starter
newfieZJ
Thanks for the heads up
All links updated and functional
newfieZJ is offline
post #8 of 13 Old 09-16-2013, 03:14 PM
PolkaPower
Is this the link to the power steering you wanted to post? http://westtexasoffroad.homestead.co...rsteering.html
PolkaPower is online now
post #9 of 13 Old 09-16-2013, 04:42 PM Thread Starter
newfieZJ
Hopefully have it this time .
newfieZJ is offline
post #10 of 13 Old 09-16-2013, 05:54 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Thanks for the include newfie.
Originally Posted by HighLonesome
coralman is offline
post #11 of 13 Old 09-16-2013, 06:08 PM Thread Starter
newfieZJ
No prob my friend . Thank you for your efforts and a good job
I gotta try to edit in some heading details for the added links later . Feel free to add links to this thread .
newfieZJ is offline
post #12 of 13 Old 12-07-2014, 11:45 AM Thread Starter
newfieZJ
newfieZJ is offline
post #13 of 13 Old 12-07-2014, 01:37 PM
durango-bob
2006 WK
Here's one that I use quite a bit. The Factory Service Manual:
http://www.jeep4x4center.com/knowled...anding+125x125
durango-bob is offline
end links 97 ZJ Steve ZJ Grand Cherokee Forum 8 07-30-2008 04:08 PM
Stabilizer bar links???? raven999 ZJ Grand Cherokee Forum 0 03-22-2008 05:55 PM
What's your favorite.... DTrem08 ZJ Grand Cherokee Forum 1 02-23-2008 10:34 PM
What was or will be your favorite mod to your WK? coyote runner WK Grand Cherokee & XK Commander Forum 28 02-22-2008 07:57 AM
End links rubbing 97_ZJ_Limited ZJ Grand Cherokee Forum 9 02-09-2006 06:45 AM
