Newbiee Question?? - grand cherokee thumping question - JeepForum.com
post #1 of 3 Old 10-21-2009, 11:14 PM Thread Starter
geoff6194
Alright... I am a newbie only posting once before. I bought a 97 grand with a v8 and installed a axle from a 98 5.9L. I was told that it would bolt in no problem no mods at all. It turns out that the drive shaft to axle U-joint is bigger on the 5.9L. I swapped the U-joints back to the stock 5.2L avle U joints, But now I am Test Driving The Truck and as I hit Bumps it is clicking or thumping from the rear end. Are these two axle's both 3.73?? Also, as i Shift from N to R and Back to D there is a thumping noise maybe from behind the front seats or the rear axle..... when I drive down the road there is a howl from the rear that sounds like woah woah woah....ell Me worst case scenario so that I can make an easy fix...
Do I swap axles again? rebuild current axle from 5.9L? replace drive shaft to 5.9: specs? replace replace NV249 Transfer case from the 5.9L? or the standard transfer case from the 5.2L? please let this guy know?? Geoff
geoff6194 is offline
post #2 of 3 Old 03-23-2011, 01:15 PM
Zj93
sounds like something is lose maybe since it happens when power goes threw the drivetrain
Zj93 is offline
post #3 of 3 Old 03-23-2011, 01:59 PM
Foundrydude
You need what's called a combination U joint with 2 caps bigger. The way you're running now mimics what happens when a U joint is trashed, noise vibration etc. The axle side of the joint is not centered because the joint is too small.
Find a parts guy that knows U joints and tell him the situation. He'll sell you a 1310 combo joint after looking both trucks up.
good luck with the project
Foundrydude is offline
Different Grand Cherokee fan question Captbullet ZJ Grand Cherokee Forum 0 01-10-2009 01:03 PM
A/C question 96 4.0 grand Cherokee cromero ZJ Grand Cherokee Forum 1 07-15-2007 02:50 PM
Question About '01 Grand Cherokee saltybeef ZJ Grand Cherokee Forum 4 04-02-2007 07:45 PM
HELP! Grand Cherokee Making thumping noise in RF Wheel!! zincmann ZJ Grand Cherokee Forum 4 07-25-2005 07:19 PM
grand cherokee question jeepthing2000 ZJ Grand Cherokee Forum 10 07-05-2005 10:46 AM
