Newbie looking at early model Jeep GC's. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Newbie looking at early model Jeep GC's.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerra
Unread 01-14-2002, 01:17 PM   #1
dc
What do I need to look for?
What can I expect to go out and when? Water pumps, brakes, belts (timing chain or belt?), etc.
I'm currently looking at 1994 GC with 136k miles, 6-cylinder I believe, asking $4,000.
Thanks!
dc is offline   Reply With Quote Quick reply to this message
Unread 02-25-2002, 01:13 PM   #2
Stormin
I would get the V8. The automatic with the 6 does not perform.
Stormin
95 JGC, 4.0L, Auto, Select-Trac
Stormin is offline   Reply With Quote Quick reply to this message
Unread 02-25-2002, 02:19 PM   #3
marley1
I just recently bought my first car. I just got a 94 Grand Cherokee, auto with the 6cyl with 100000miles for 6grand. I test drove the v8 and really i wasn't that much impressed. The 6 has pretty good acceleration and has enough for me being a high school student and the insurace will be alot less. If you got the money to spend on gas and insurace then buy the v8 but the 6cyl is plenty fast and their is some things you can add to it to give a little more power(exausht...)
Good luck
marley1 is offline   Reply With Quote Quick reply to this message
Unread 02-25-2002, 07:23 PM   #4
Kess
i have a 94 gc with 126k and within the last year i have replaced the water pump and the heater core, tahts about it, hc was expensive but that is usually pretty rare to go out, water pump 50 bucks and ur set, easy to do by ur self
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline   Reply With Quote Quick reply to this message
Unread 02-26-2002, 08:04 PM   #5
The^Knightmare
I bought my 94 GC with 60K for 4,700, it now has 70K and ive only had to do regular mantinence to it, change oil etc, but I did have to change the brakes and rotate tires, the usuall stuff, nothing major
94 JGC Laredo sorta stock
- K&N Custom Air Intake
- 20x8.5 Enkei AKAs
- 3JL 12W6s w/ Kicker ZR600
The^Knightmare is offline   Reply With Quote Quick reply to this message
