Newbie with Idle problems - JeepForum.com
post #1 of 6 Old 01-20-2002, 10:57 PM Thread Starter
MickeyAsh
Hello guys! Just bought a '95 Laredo 4x4 I6 that idles around 500rpm, which is pretty rough feeling, if I tap the gas and get it to 1k rpm, it falls down to 700rpm and purrs like a kitten, then in a few seconds falls back to 500rpm. I read something about adjusting the TPS to DECREASE idle speed, can I do the same to increase it? Any ideas? Thanks in advance!!
-Ash
MickeyAsh is offline
post #2 of 6 Old 01-21-2002, 08:14 AM
Lazlo
I was having a similar problem with my 97. I replaced the idle control valve for $39 and it runs like new now. Good luck.
Lazlo is offline
post #3 of 6 Old 02-01-2002, 12:23 AM
kuzma97ZJ
my 97 did almost the exact same thing and i changed the throttle position sensor and that fixed it. when i changed it i didn't see any way of adjusting it, maybe it is diferent on a 95.
hey goodluck......
1997 grand cherokee 4.0L, forest green, 3" skyjacker, 1" spacers, adj. front track bar, skyjacker sway bar dissconnects, procomp steering stabilizer, 31" super swamper LTB's, safari bar w/ 2 KC's, custom roof rack w/ 2 KC's, tow hooks front and back, CB, dynomax turbo muffler, custom K&N filter charger, 2 12" sony explode subs.
kuzma97ZJ is offline
post #4 of 6 Old 02-03-2002, 10:23 PM
Neil
Check the motor mounts too (trans mount also). this is a common problem.
5.9 ZJ
98 ZJ 5.2
Neil is offline
post #5 of 6 Old 02-06-2002, 08:13 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
to adjust - loosen screws, just a little, and twist it. you'll hear the idle go up or down. i have adjusted mine. don't loosen them completely. just enough to where you can TAP it with a small hammer or the backside of a scewdriver.
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #6 of 6 Old 02-06-2002, 01:57 PM
PSDesertXJ
Hi there - Just bought a 93 ZJ and am having similar probs. Only in my case, idle speed drops (and occasionally it stalls) but only after the engine has really warmed up. Cold idle is purrfect. Any thoughts?
Thanks in advance - MJ
PSDesertXJ is offline
Newbie.....transmission problems mguerra1614 ZJ Grand Cherokee Forum 6 11-13-2009 03:32 AM
Low Idle Problems Ziesemer ZJ Grand Cherokee Forum 1 09-14-2009 07:48 PM
help a newbie here - clock problems historyfool24 ZJ Grand Cherokee Forum 10 09-25-2005 07:40 PM
Newbie Questions/Problems djtalon ZJ Grand Cherokee Forum 3 04-02-2005 07:27 AM
IDLE Problems 97GCherokee ZJ Grand Cherokee Forum 2 04-15-2002 10:25 AM
