Newb with a technical axle question - JeepForum.com
post #1 of 4 Old 02-19-2013, 06:33 PM Thread Starter
Maine1994ZJ
Hello to you all!! Kind of new to off roading, but learning all the time. My question is:
I may possibly have access to the axles from a WJ with the Quadra-Drive gerotor style diffs for less than dirt cheap. I was wondering if the carriers are a direct swap from WJ housings to ZJ housings, or are there different bearing sizes/shaft sizes/ring & pinion sizes/# of splines between the 2 generations that would make it not viable? I know the WJ axles are wider and have different bolt patterns, but are the internals all different from the ZJ axle innards?
Both front axles are Dana 30LP, one 1994, the other 2001.
Both rear axles are Dana 35, 1994 and 2001 also. I know... D35s are junk... but for now I can't swing the $$ for a REAL axle... lol
Any info would be helpful!!
Thanks!
Rob
Maine1994ZJ is offline
post #2 of 4 Old 02-20-2013, 07:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Shaft sizes are different between open and varilock axles. You'd need custom shafts.
Varilock only came in the 44a, never the d35.
ratmonkey is offline
post #3 of 4 Old 02-20-2013, 10:21 AM Thread Starter
Maine1994ZJ
Thanks. I knew there would be something different about them so it wouldn't be just a simple swap out. LOL I always try to learn something new every day
post #4 of 4 Old 02-20-2013, 11:10 AM
1stblack97ZJ
welcome to jeep forum
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
