NEWB 2" lift question: spring lift vs bb lift - JeepForum.com
post #1 of 5 Old 01-12-2011, 07:29 PM Thread Starter
squiretdi
Alright, i'm looking for 2-3" of lift and to me there seems to be something wrong with using poly/aluminum blocks to lift my zj. so I have been searching for a 2-3" spring lift, and have only found the one that is sold by fat bob's garage:
http://store.fatbobsgarage.com/_jeep...998-p7911.aspx
http://store.fatbobsgarage.com/_jeep...998-p7551.aspx
I say that I prefer full suspension lift, because I am currently used to lowering cars and lifting an suv with a full suspenion of shocks and springs makes more sense to me. I understand that it is more expensive, but as with my summer fun car
i understand having to pay to play....
the goal is to have a nice looking zj with offroad capability when i want it but is comfortable enough to drive for a good distance and do some light towing or parts hauling
i guess i'm looking for suggestions of other companies that make similar lifts or opinions on the kits listed above
squiretdi is offline
post #2 of 5 Old 01-12-2011, 09:05 PM
94yj03wj
2003 WJ
Check out Iron Rock Offroad, the last I checked the smallest complete lift they had for a zj was 4.5". Bds also has a few kits but I would go with their 4.5 since their 3" kit doesn't seem complete. I know you said you were only looking for 2-3" of lift but so was I utill I decided on a 4" lift from bds and couldn't be happier with it. They say no just stops with a budget boost so you mine as well skip to the next step.
2003 WJ Laredo 4.0 I6 with Selec-Trac, 4” BDS lift with 32” Goodyear wrangler Duratracs, KC Slimlites mounted on Kevin’s Offroad Light Bar, Rusty’s Recovery Hooks and T-Case Skid, Midland CB,(Daily Driver)
1994 YJ With 30” Interco TSLs (Project Jeep)
94yj03wj is offline
post #3 of 5 Old 01-12-2011, 10:12 PM
marcua56
Check out Iron Rock Offroads 3.5 inch lifts http://www.ironrockoffroad.com/Merch...egory_Code=PFZ
This sounds right up your ally and you want a really good ride do the bilstien upgrade. This lift takes your front coils and moves them to the rear and the new coils in the kit replace the fronts. The adjustable trac bar is a good idea at 3 inches. A rear adjustable trac is a good idea but not a must if moneys tight. Oh and sway bar end links are a must at 3 inches, get quick disconnects if you plan to really flex it out often. Hope this helps
marcua56 is offline
post #4 of 5 Old 01-12-2011, 10:24 PM Thread Starter
squiretdi
I was looking at iron rock offroad, and wondered if these could replace the factory front springs to be put in the rear....
http://www.ironrockoffroad.com/Merch...egory_Code=ZSC
post #5 of 5 Old 01-12-2011, 10:50 PM
marcua56
I would assume so if now look for a upcountry from a parts store
marcua56 is offline
2.5" wj spring lift? StoveBolt ZJ Grand Cherokee Forum 23 03-20-2007 06:48 PM
ZJ 3" spring lift ericheineman01 ZJ Grand Cherokee Forum 8 12-28-2006 07:53 AM
Possibly the biggest newb lift question ever evans1010 ZJ Grand Cherokee Forum 2 08-20-2006 05:08 PM
6" lift spring measurement for WJ FearTheDentist ZJ Grand Cherokee Forum 41 07-27-2006 01:37 PM
Who Sells WJ spring for a 2" lift or less ? 2Grand4s ZJ Grand Cherokee Forum 3 02-23-2005 09:07 PM
