New to ZJ and i have a wee problem with overheating. - JeepForum.com
post #1 of 6 Old 08-13-2012, 08:49 PM Thread Starter
Concolour
1994 ZJ
Ok. so i just bought this 94 grand cherokee limited with the 5.2 a month ago. and just this week it started overheating. first i noticed that there was coolant bubbling out of the overflow, usually after shutting it off. and yes, it was still boiling in the reservoir. but other than that just that it will come up to temp really fast and eventually up to the redline while at any speed including just idling.... it's been a long long time since i've done anything cooling related. there's no leaks that i can detect, just from the cap of the reservoir. the fan is indeed working, and the rad isn't blocked/bent fins. this leaves me with three things that i can think of. a clog, water pump, or thermostat. or even a combo of all three. are there any symptoms that would show for any of those so i know what part to order and replace/fix? would like this fixed asap as its currently the DD.
thanks for any and all help
-Puma
Concolour is offline
post #2 of 6 Old 08-14-2012, 12:18 AM
KennzX
Get a new cap, burp the system. Should be good after that.
Jeep, The dirtiest of the four-letter words
Not stuck; temporarily detained
KennzX is offline
post #3 of 6 Old 08-14-2012, 12:43 AM Thread Starter
Concolour
1994 ZJ
actually just tried that..... it didn't work. not sure why when it should have given what i've seen is wrong. but. i'll try reburping the system and go from there.
anything else i could try?
post #4 of 6 Old 08-14-2012, 05:58 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Cap? With the motorat idle at operating temp, touch the upper and lower hoses. Is either hose "cold"? Have you flushed the radiator? Changed the thermostat or waterpump?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 6 Old 08-14-2012, 10:55 AM Thread Starter
Concolour
1994 ZJ
Hunter
I'll try that when I get home. Thermostat and wp will have To wait for parts
post #6 of 6 Old 08-15-2012, 06:07 PM Thread Starter
Concolour
1994 ZJ
alright ^.^ went and checked it out. let it heat up and lo and behold? thermostat was stuck closed XD so swapped that out, or rather, one of the tech's at work did and if anything it runs a bit cold now X3 thanks for all the suggestions. especially hunter, who practically diagnosed it from his desktop. i'm sure the rad cap was also a culprit in this case too, so thank you too, KennzX!
cooling , overheating , thermostat , water pump , zj
Overheating problem? hdcmfan WK Grand Cherokee & XK Commander Forum 2 06-12-2011 11:51 AM
overheating problem! drob951 ZJ Grand Cherokee Forum 13 07-10-2009 10:26 PM
overheating problem???????? snowgoer987 ZJ Grand Cherokee Forum 4 05-05-2008 08:17 PM
Overheating problem? DTJ ZJ Grand Cherokee Forum 19 10-29-2007 10:10 AM
99 WJ 4.7 Overheating problem ? 99WJ4.7limited ZJ Grand Cherokee Forum 11 05-24-2006 06:23 PM
