New Zj? - JeepForum.com
post #1 of 16 Old 04-08-2013, 08:02 PM Thread Starter
tizzly
1994 ZJ
New Zj?
So im stuck between a new zj and a wrangler (yj or tj). Ill have the 94 zj as a trail rig from now on.
What do you guys think, should i get a new zj or move to something else.
There are a few 5.9s up for sale in my area by the way
tizzly is offline
post #2 of 16 Old 04-08-2013, 08:39 PM
capcyclone
capcyclone's Avatar
Why not go with a new niner - and then you can always cannibalize your "trail rig" at some point if it begins to get to that point (as a parts vehicle)?
I've really thought long and hard about a Wrangler too, but I keep coming back to the decision to stick with my ZJ - it's too versatile to move away from.
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #3 of 16 Old 04-08-2013, 09:24 PM Thread Starter
tizzly
1994 ZJ
I want a stick shift, but i could foget all about it with enough power. I replied to a 5.9 craigslist post an hour ago. Well see how it goes but for 1600 im thinking something might be wrong with it
tizzly is offline
post #4 of 16 Old 04-08-2013, 09:33 PM
kg6mov
Hears the voices
kg6mov's Avatar
As rat proved, you can throw a 5 speed behind a niner. Once you try it you'll be addicted.
kg6mov is offline
post #5 of 16 Old 04-08-2013, 09:47 PM Thread Starter
tizzly
1994 ZJ
Is there a way around the CEL from the auto to manual swap. Ny has those stupid yearly inspections
tizzly is offline
post #6 of 16 Old 04-08-2013, 09:52 PM
kg6mov
Hears the voices
kg6mov's Avatar
Rat lives in an inspection state, I think he swapped ECU's
kg6mov is offline
post #7 of 16 Old 04-08-2013, 10:04 PM Thread Starter
tizzly
1994 ZJ
I'll have to do some research then, thanks
tizzly is offline
post #8 of 16 Old 04-08-2013, 10:10 PM
kg6mov
Hears the voices
kg6mov's Avatar
Don't get a yj, you really don't want to deal with front leafs.
kg6mov is offline
post #9 of 16 Old 04-09-2013, 12:07 AM
Rich93ZJ
Check this out
Rich93ZJ is offline
post #10 of 16 Old 04-09-2013, 02:02 AM
Uniblurb
Uniblurb's Avatar
Personally I'd go with another ZJ rather than a TJ. My wife has a 2000 TJ 4.0 Sahara I do all the maintenance/repairs on and there's very few things I like about it as far as a road vehicle. With a high center of gravity/short wheel base it gets blown all over the road by trucks/any wind while feeling unstable, even new HQ rag top is louder than heck, cold in winter/hot is summer, rusts even worse than my ZJ, etc.
Had to replace the left front fender last year because it was rusted through the top and now the right front fender needs replaced for the same rust problem. Had to replace a bad/leaking AC evaporator, like I did on my 96 ZJ, but you would have thought it wouldn't go out at the same time as mine being 4 years newer. And good luck hauling anything with a 1 1/2' x 3 1/2" space behind the back seat.
Every time we go anywhere together we take my ZJ and just leave the TJ sitting in the drive. Just my opinion and stick to ZJ's...
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #11 of 16 Old 04-09-2013, 02:19 AM
just_urd
Wish I had a time machine to have a sit down with the zj designers to initiate a manual transmission option for all engines and options...
just_urd is offline
post #12 of 16 Old 04-09-2013, 09:27 AM
kg6mov
Hears the voices
kg6mov's Avatar
The problem is that nothing in the mopar bag of tricks is rally correct for the v8 zj, the nv3500 and ax15 are a bit weak for the v8, and the nv4500 wont fit in the tunnel.
kg6mov is offline
post #13 of 16 Old 04-09-2013, 03:34 PM Thread Starter
tizzly
1994 ZJ
Well the Yj i was going to look at was sold, to bad. Theres a few cheep Zjs around and i might be able to pull a transmission conversion out of it if i play the cards right
tizzly is offline
post #14 of 16 Old 04-09-2013, 05:19 PM
bananaslug
Having a ZJ trail rig and DD TJ is *** backwards. Get a ZJ, itll be much more comfortable and cheaper.
bananaslug is offline
post #15 of 16 Old 04-09-2013, 09:50 PM Thread Starter
tizzly
1994 ZJ
I found a 95 ram today with the 5.2 + standard trans. If i can talk him down a little on price i might pick it up. Drive it for a while till i get a Zj with a bad trans, and then do a swap. Im not sure what the trans is but if it ends up being a NV4500 or similar ill have to do some sheet metal work before the swap.
Just thinking!
tizzly is offline
