New water pump...aftermarket or Mopar? - JeepForum.com
post #1 of 22 Old 05-08-2013, 07:14 AM Thread Starter
brewcity1
Hey guys...doing the plenum repair (as you can see from my posts ), and I am going to replace the water pump. Just need some advice about going with an aftermarket one seen here:
http://shop.advanceautoparts.com/web...gmb_19760061-p
or should I stick with a Mopar one?
Thanks for the help and guidance. I really appreciate it.
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #2 of 22 Old 05-08-2013, 07:37 AM
PolkaPower
I wouldn't buy that cheap crap. This is not something you want to do soon again. If you want an upgrade try this one. http://www.hesco.us/products/7967/hi...8#.UYpXgoUpSvU
PolkaPower is offline
post #3 of 22 Old 05-08-2013, 07:39 AM
dnuccio
Im running an ACDelco water pump (new, not reman) from rock auto. Only cost around 40 bucks. Works great
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 22 Old 05-08-2013, 07:44 AM Thread Starter
brewcity1
Thanks...I was looking for new and not re-manned!
Thanks a lot....my thoughts exactly...thats why I asked. I just dont know much about aftermarket water pumps, and if they last or not. Sounds like the AC Delco is a good option. I found a Mopar pump new, so will just go with that.
Thanks again!! You guys are great!
post #5 of 22 Old 05-08-2013, 07:50 AM
PolkaPower
AC Delco isn't quality anymore. I would not run anything but a Mopar OEM or that Hesco I linked. I think Flow Kooler has updated their design on the impeller so that might be an option too. The Mopar unit should be just fine though. This is a critical part that could leave you on the side of the road. Don't cheap out.
post #6 of 22 Old 05-08-2013, 08:25 AM Thread Starter
brewcity1
OK...very good point! I will go ahead and order the new Mopar water pump.
Thanks a lot!
post #7 of 22 Old 05-08-2013, 11:17 AM
moparlover1992
I just put a flowkooler on mine. I think it has a lifetime warranty so I'm keeping my invoice in case it ever does go. The propeller design was definitely different than the stock one. It is also a high performance pump. Bit cheaper than the other one linked. See how long it lasts I guess...
95 zj 5.2 np242 3.5'' IRO lift, IRO adjustable arms, KOR front trackbar, steering stabilizer and box brace, IRO rear adjustable trackbar, bilsteins, Hughes plenum plate, flow master 40, 31x10.5s on 15'' dc-2 rims
Mopar or no car!
moparlover1992 is offline
post #8 of 22 Old 05-08-2013, 11:43 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Just replaced my Flowkooler under warranty. Started leaking from weephole after about a year. Summit was great to deal with.
HighLonesome is offline
post #9 of 22 Old 05-08-2013, 11:57 AM
PolkaPower
Is the impeller cast or is it riveted? Thats the part that I read could fail leaving you stuck. I don't know if they up dated the design.
post #10 of 22 Old 05-08-2013, 12:01 PM
HighLonesome
geez, didn't really notice
the plate was welded to the impeller tho
post #11 of 22 Old 05-08-2013, 12:04 PM
Pierre_r
1989 XJ Cherokee
I have a Gates waterpump in mine and i have had it for a year now without any problems.
Pierre_r is offline
post #12 of 22 Old 05-08-2013, 12:52 PM
KJK
I've replaced a Flowkooler and 2 Mopar pumps for leaking weep holes after just over a year each. I'm now running an Autozone one on it's 3rd year and it's been great.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #13 of 22 Old 05-08-2013, 01:38 PM
moparlover1992
Did you need two gaskets when installing your flowkooler? i used two on mine. it said some may need both in order for it to spin freely...
Mopar or no car!
post #14 of 22 Old 05-08-2013, 01:43 PM
HighLonesome
just needed one..
the old flowkooler used one and there was no sign of the impeller touching the block.
post #15 of 22 Old 05-08-2013, 01:53 PM
moparlover1992
just needed one..
Thanks just curious
Mopar or no car!
