new tyres - JeepForum.com
post #1 of 28 Old 11-13-2008, 02:59 PM Thread Starter
Michelle32
new tyres
Hi there, I have just lifted my Jeep and am putting on new Mickey Thompson 32" Tyres tomorrow - I have been told that if I damage one and put a smaller sprae tyre on I will blow a diff...can anyone confirm that this is the case??
cheers, Michelle
Michelle32 is offline
post #2 of 28 Old 11-13-2008, 03:06 PM
CLNinja
CLNinja's Avatar
first of all there Tires ( silly aussies )
and second.. we need to know more information about your Jeep to determine if you will need to replace all 4 tires in the event of a blowout
do you have all time four wheel drive? or do you have an option for 2 wheel drive and 4 wheel drive?
basically.. which transfer case do you have?
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #3 of 28 Old 11-13-2008, 03:14 PM Thread Starter
Michelle32
thanks Matt...it is constant 4 wheel drive...I don't know what transfer case it is sorry...blonde you know!!
post #4 of 28 Old 11-13-2008, 03:19 PM
CLNinja
CLNinja's Avatar
if it is always in 4 wheel drive then yes.. you need matching tires all the way around... if you get a flat and need to put a spare on.. there is a certain amount of tread difference that is acceptable... too much will cause problems
Matt
CLNinja is offline
post #5 of 28 Old 11-13-2008, 03:21 PM
99avant
Transfer case is what decides how much power will go to each wheel. If one wheel is smaller and is spinning faster, it will confuse and burn up the fluid and internals of the transfer case.
Here is a diagram from wjjeeps.com with the location of the transfercase- just for your reference.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #6 of 28 Old 11-13-2008, 03:25 PM Thread Starter
Michelle32
thank you both for your help and diagrams!! - it is much appreciated! new tyres here I come!!!
cheers Michelle
post #7 of 28 Old 11-13-2008, 04:48 PM Thread Starter
Michelle32
just one more thing....can I please have any suggestions on where to carry my new spare tyre as I don't think it will fit in the space that the current spare tyre is stored.....
cheers, Michelle
post #8 of 28 Old 11-13-2008, 04:55 PM
dxmedia
Originally Posted by CLNinja View Post
first of all there Tyres
There you go, fixed it for you
dxmedia is offline
post #9 of 28 Old 11-13-2008, 05:11 PM Thread Starter
Michelle32
good one!! can you fix my spare tyre storage problem???
post #10 of 28 Old 11-13-2008, 05:57 PM
99avant
-aftermarket or custom made rear bumper with tire carrier
-on the floor of the trunk
-rooftop tire carrier (http://kevinsoffroad.com/wj/wj_tirecarrier.html)
99avant is offline
post #11 of 28 Old 11-13-2008, 09:43 PM
jeepinjoe123
1994 ZJ
the allowable amount of tread difference is 4/32" per the factory manual
1994 JGC limited 5.2l 4in F>R swap 31in. dune grapplers, soft 8's, flowmaster 40 series and duals out the sides, taurus e-fan, high flow intake, 231 swap, 44a swap, NGK plugs, Shell 93 octane only, homemade choppped and drilled light bar, gold>black stripes, in the process of making true cowl induction hood and putting 96-98 cladding, bumper cover, and grill on
jeepinjoe123 is offline
post #12 of 28 Old 11-13-2008, 11:27 PM
Tiggerrrrr
1/8"? I should check mine.. oh well, I want new tires and a 242 anyway.. lol
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #13 of 28 Old 11-14-2008, 12:02 AM
Dark
Dark's Avatar
@CLNinja
...first of all it's they're or they are.
2002 WJ 4.7L -
1998 TJ 4.7L -
Dark is offline
post #14 of 28 Old 11-14-2008, 12:03 AM
MEinSoCal
which lift did you go with?
i too have a 32in M/T spare and obviously it doesn't fit in the spare tire well. what i did was just stand it up to one side and hold it in place via a rachet type strap.
MEinSoCal is offline
post #15 of 28 Old 11-14-2008, 12:11 AM
CLNinja
CLNinja's Avatar
Originally Posted by Dark View Post
@CLNinja
i already used first of all... yours would be "second of all"
Matt
CLNinja is offline
Want to put 33" tyres on my WJ...... Radosl81 ZJ Grand Cherokee Forum 4 06-09-2009 12:48 PM
zj stocker tyres bigpaul ZJ Grand Cherokee Forum 0 01-07-2009 06:15 PM
Tyres kevsjeep ZJ Grand Cherokee Forum 10 10-24-2007 08:19 AM
Tyres for WJ ktiek ZJ Grand Cherokee Forum 3 12-16-2006 09:40 AM
Tyres kopite77 ZJ Grand Cherokee Forum 16 06-15-2006 02:14 AM
