new transmission, same problems - JeepForum.com
post #1 of 14 Old 02-22-2010, 05:55 PM Thread Starter
jeffp2152
I started having problems with the transmission on my 93 gc. 4.0, 42re transmission. The transmission would not downshift unless I did it manually with the shifter. Going from a stop in D the jeep would slip a lot and slowly go forward until it picks up some speed then it goes fine in D, but still wont downshift. Reverse works fine.
I got a rebuilt transmission and installed it. Same problems. I added fluid, let it warm up, checked the fluid again and it was fine. Reverse works fine. But still wont downshift unless I do it manually.
Also, I noticed that my O/D switch, right underneath the rear wiper switch, does not work either. And I don't believe it has since the problems started. So I also have no O/D.
What are my possible problems now?
- Throttle valve cable?
- wiring?
- PCM?
jeffp2152 is offline
post #2 of 14 Old 02-22-2010, 06:01 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Possibly overdrive unit (although I dont think that would cause it to not downshift)
Possibly kick down cable (although Im not sure if that would have anything to do with the o/d)
Possibly PCM.
At this point, if I were you, I would take it to a tranny shop or dealership for a diagnosis. May cost you a few bucks to have them look at it, but at least you would get a better idea of what the problem is before you go dumping money into guesses.
~James
ezflip is offline
post #3 of 14 Old 02-22-2010, 07:25 PM
psyviperx
check the fuses under the hood by the transmission relay
04 Overland | K&N Intake | Kumho AT51
(Hers)
97 TJ Sport | D30/35 | Mods incoming...
(His)
psyviperx is offline
post #4 of 14 Old 02-22-2010, 07:29 PM
ZeeJay1997
The 93 does not have PCM. It has ECM and TCM. TCM is suspect.
ZeeJay1997 is offline
post #5 of 14 Old 02-22-2010, 09:20 PM Thread Starter
jeffp2152
oh I didn't think I even had a tranny computer? are those just plug and play if I grab one from the junkyard?
post #6 of 14 Old 02-22-2010, 11:36 PM
MoonyJohn
What gears does it run? Does it up shift at all? Mine starts in 3rd when in D, it wont upshift or downshift unless i downshift manually. I can get into first if i slam it from neutral to 1. I took my jeep today actually to a transmission shop, pulled some codes and got codes for the Torque Converter Clutch (TCC), which is in part with the governor pressure sensor and 3-4 upshift. Not saying that this is your problem, but it might help mine. Im 90% positive that the new Governor Pressure Sensor, Solenoid, and TCC Solenoid it will fix my symptoms.
Once again, what gears are you able to run in, and what gear does it start in?
Heres a link to the 3 parts that could fix your shifting problems.
http://newyork.olx.com/transmission-...-68524073#pics
If you can, go get it scanned somewhere. Get the codes so you dont start looking in the wrong direction. I got mine scanned for 26 bucks.
MoonyJohn is offline
post #7 of 14 Old 02-23-2010, 12:49 AM Thread Starter
jeffp2152
Transmission Parts 42re 46re Solenoid Kit Dodge - New York - Car Parts
Sounds like my problem. Starts in three from a stop in drive. Will go into first if I slam it... But I had this problem and changed the transmission and still have the same problem. To me it sounds like it has to be something external?
post #8 of 14 Old 02-23-2010, 02:44 AM
perfectcircle
PCM/ECM, same damn thing. But yes, unlike 4.0 WJs, the TCM is a stand alone unit.
If you're having the same issues as the last transmission, read the codes and I'd be surprised if you didn't a) have an open fuse b) have a wire grounding out in your harness or c) have a faulty computer. If the transmission was rebuilt, the electronics should have been replaced (though they may not have been so it COULD be the culprit) but what are the chances it's not something related to the vehicle itself? Slim, I say.
Just because you are missing 1st and OD and can force it into them, does not mean anything. Your transmission is in LIMP MODE. it means it detected a fault (threw a code..OD light is on thats a sign something is wrong) and is protecting itself from further harm. By abusing the transmission and forcing it into gears it does not want to be in, you could cause further damage to your newly rebuilt transmission. Being in limp mode does not mean you have the same problem as joe schmo who always had his transmission stuck in limp mode, it simple means you have an electronic fault present and you need to find out what it is, and fix it.
perfectcircle is offline
post #9 of 14 Old 02-23-2010, 04:01 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Limp mode is to get t the nearest service station and driving around in it will cause more damage than manually shifting the gears.
Sounds like a power or computer problem. Though you NEED the obd codes to know where to start.
ratmonkey is offline
post #10 of 14 Old 02-23-2010, 04:46 AM
ZeeJay1997
Technically, they are not the same. 96 and above have PCM and previous years have ECM + TCM.
post #11 of 14 Old 02-23-2010, 08:17 AM Thread Starter
jeffp2152
Thanks for all of the input guys. Today I am going to go get another tranny computer and see if just switching them out fixes the problem. I'm also going to check fuses and wiring, and run the codes and see what I can find out.
To get to the tcm do I need to pull the dash off or is it lower along the firewall? to the left of the steering rod with a **** ton of wires coming out of it?
post #12 of 14 Old 02-23-2010, 03:53 PM
ZeeJay1997
I'll bump it and say i don't know where it's located.
post #13 of 14 Old 02-23-2010, 11:21 PM Thread Starter
jeffp2152
Well, thanks to everyone here at the forum, my jeep is back on the road again working good.
I did some searching for the 42re tcm and found someone with the same problem as me, and it turned out to just be the fuse.
Well that was it. Boy do I feel stupid for not checking it 3 months ago.
O well, I now have a newer rebuilt tranny and transfer case.
The only thing I noticed(did this before the tranny change) is that I can hear the tranny fluid being pumped when the car is cold. Is this normal? only happens if I rev it up before driving it. Never did it in warmer weather, and its only about 20 degrees here now
post #14 of 14 Old 02-24-2010, 01:14 AM
perfectcircle
What'd I tell ya?
96 GC Transmission problems TowMaster ZJ Grand Cherokee Forum 2 12-29-2008 09:24 PM
transmission problems dex1 ZJ Grand Cherokee Forum 1 11-29-2008 07:47 PM
transmission problems dex1 WK Grand Cherokee & XK Commander Forum 1 11-29-2008 05:22 PM
Transmission problems. HELP! jmack549 WK Grand Cherokee & XK Commander Forum 9 10-30-2008 11:01 PM
transmission problems 01gt ZJ Grand Cherokee Forum 5 11-14-2007 05:47 AM
