New transmission - JeepForum.com
post #1 of 7 Old 03-07-2013, 07:16 AM Thread Starter
garretthadsell
New transmission
Anybody know if there is a standard.transmission that will bolt directly up to a 98 4.0 im tired of the auto and its also going out
garretthadsell is offline
post #2 of 7 Old 03-07-2013, 07:33 AM
LordHobbit
nothing easily.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 7 Old 03-07-2013, 10:30 AM
TheRealOldjeep
AX15 would be the stock 4.0L manual trans in most jeep products. It wouldn't be a particularly easy swap - could you even get a stick in a 98 GC stock? Better off just rebuilding the AW4.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #4 of 7 Old 03-07-2013, 03:01 PM
spidermonkey
42RE, AW4 were only in 93-94 ZJs and 87-01XJs.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 3.5" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here:
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers
spidermonkey is offline
post #5 of 7 Old 03-07-2013, 03:10 PM
TheRealOldjeep
Well then maybe an AW4 swap would be an idea. Definitely a better transmission.
Chuck P
My site
post #6 of 7 Old 03-07-2013, 05:01 PM
jmonty0523
you can only run a 42RE without not getting cel codes. the TCM is in the PCM and there is no way to override or bypass it for a 5 speed.
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #7 of 7 Old 03-07-2013, 05:14 PM Thread Starter
garretthadsell
I didnt think about that thanks I guess its rebuild time
