New timing chain...leave it stock or change the timing? - Page 2 - JeepForum.com
post #16 of 20 Old 05-14-2013, 08:06 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Dodge/jeep uses sequential multi port injection.
Fuel synch would not be nearly as critical if it didn't.
10* out of synch and you'll have higher end power issues and a rough idle. By 15* it'll start but you wont be able to drive it.
The snap on unit is just as expensive and few garages carry it or a drbiii.
ratmonkey is offline
post #17 of 20 Old 05-14-2013, 08:43 AM
MN59ZJ
Leave. It stock & get a SCT tune.
MN59ZJ is offline
post #18 of 20 Old 05-14-2013, 06:21 PM
blown50
1987 YJ Wrangler
I stand corrected on the sequential injected, I was thinking of an older model, and as the reluctor ring only has one opening I was under the impression it was batch fire. I don't have a tuner for the obd 2 on a jeep. so I had no need to know. It's cheaper for me to go with a mega squirt computer than buy or build a tuner! However we seem to disagree on the 4 degree advance! I will agree that if the reluctor ring was a few degrees out of sync, then it might start to pose a problem. But if the reluctor ring was out of sync then I would think due to the small dizzy cap, there would also be rotor phase problems. Which could be mis diagnosed as a fuel sync problem. Any ho there is still so much to learn
blown50 is offline
post #19 of 20 Old 05-17-2013, 04:13 AM
homerx
Sry I always confuise the 2 lol
homerx is offline
post #20 of 20 Old 05-17-2013, 10:18 AM
SLOspeed
To degree a cam, you need the "cam card" with all the opening and closing specs (specifically the timing at 0.050 lift). Does anyone here have one? I've never seen a cam card for a stock oem cam, ever, from any manufacturer. One of the reasons for using an aftermarket cam is that it's practically impossible to properly degree a stock cam, due to the lack of information.
SLOspeed is offline
