new sway bar links? - JeepForum.com
post #1 of 8 Old 01-30-2013, 07:19 PM Thread Starter
JohnC7
new sway bar links?
I recently put in a 2.25 BB with bilstein 5100's. the front sway bar link were really tight when i was reattaching them. I had to put the bolt in the bottom and hook up a C clamp so that the link could reach hook up to the bolt. I don't know if that makes sense, all in all I feel like the sway bar links are being stressed.
My question is, should i get new sway bar links? I did some googling and found some 3" performance sway bar links. would those be suitable? What are some sites that you would recommend? I also live in Canada.
JohnC7 is offline
post #2 of 8 Old 01-30-2013, 07:27 PM
kg6mov
Hears the voices
kg6mov's Avatar
Get jks discos from somebody like kolak or kevin, they make them in different sizes for different lift and make disconnecting for trails a hell of a lot easier.
kg6mov is offline
post #3 of 8 Old 01-30-2013, 07:30 PM Thread Starter
JohnC7
Whats the benefit to quick disconnects? I don't go off roading a lot so would they be worth it?
JohnC7 is offline
post #4 of 8 Old 01-30-2013, 07:39 PM
kg6mov
Hears the voices
kg6mov's Avatar
Huge improvement in flex, if you don't go offroading you won't really need them. But that one time you do go offroading you will be glad you had them.
kg6mov is offline
post #5 of 8 Old 01-31-2013, 01:20 PM Thread Starter
JohnC7
Bump?
JohnC7 is offline
post #6 of 8 Old 01-31-2013, 02:24 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Several places sell longer links. The sway bar should be +/- 10 from level for best performance.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 8 Old 01-31-2013, 08:01 PM Thread Starter
JohnC7
How are the rubicon express front sway bar end links? Are they any good?
JohnC7 is offline
post #8 of 8 Old 02-03-2013, 12:28 AM
JohnnyZJ
they are all the same
call northshore offroad, or www.zoneoffroad.ca. they are in Vanacouver, they'll have a sway bar link that'll work for you. its fine.
07' JKUR rollin on 35s
JohnnyZJ is offline
