New Starter, No Start - JeepForum.com
post #1 of 4 Old 07-20-2011, 07:00 PM Thread Starter
NickkciN
Just replaced the starter in the ZJ cause I thought it was a bad solenoid. When i turn the key i can hear the relays click but the engine wont turn. I tried starting it in neutral and it wont work. Battery was dead but now it's charged up and still nothing happens when i turn the key.
Any ideas?
-Nick
1995 ZJ Limited
IRO 5.5" Critical Path Long Arms
Armored and Aussie locked
NickkciN is offline
post #2 of 4 Old 07-20-2011, 11:40 PM
TewSmooth18
sounds like you might have a ground issue possibly. this same thing happened to my brothers car a few days ago, what we did is we took a set of jumper cables, clipped one end of the negative jumper cable to the negative battery post (with terminal on) and the other end of the negative jumper cable to the engine. left the positives disconnected. fired right up. the original ground cable was bad. replaced the negetive cable and all is working now.
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
post #3 of 4 Old 07-25-2011, 06:31 PM Thread Starter
NickkciN
did this and it didnt work
Could it be the ignition?
-Nick
1995 ZJ Limited
NickkciN is offline
post #4 of 4 Old 07-26-2011, 07:12 AM
Virmagicus
Virmagicus's Avatar
Why did you have to charge the battery? Get the battery tested.
Jeff
Virmagicus is offline
ZJ Won't Start, No Action From Starter 98gcjeep ZJ Grand Cherokee Forum 4 03-11-2010 08:04 PM
No start - only get 6 volt to starter LWBII00 ZJ Grand Cherokee Forum 19 01-07-2010 07:21 PM
no start - only getting 6 volt to starter LWBII00 WK Grand Cherokee & XK Commander Forum 1 01-02-2010 09:02 PM
New starter and wires no start! metallica0682 ZJ Grand Cherokee Forum 11 09-03-2009 12:03 PM
01 GC sometimes doesnt start (as if the starter went) Heracles ZJ Grand Cherokee Forum 2 08-18-2007 09:33 AM
