New to this site and Grand cherokees - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > New to this site and Grand cherokees
Rough Country Deals at JeepHut.comSave at JeepHut on Smittybilt Soft topsUp to $75 Cash Back on Your ARB Fridge Freezer Purchase
Unread 08-13-2014, 08:53 AM   #1
davev8
Hello all,
So I was on Craigslist the other day and happened upon the steal of the century. Some guy selling his aunt's grocery getter for cheap. A '96 red grand cherokee limited with, wait for it...85,000 miles and wait again...for 1800 bucks. I've driven it for a couple weeks and nothing has fallen apart so I think I might be in the clear as far as whether it's a lemon or not.
I joined the site for some wisdom from those who have this model and might impart some knowledge as to what to look out for and whatnot.
It's bone stock (grocery getter) and the engine is strong but there are a couple things goin on. It won't come out of 4 high and the sunroof is sagging. Not being too mechanically inclined, I am gonna take it to a buddy's shop, get her feeling good and throw a coat of paint and probably some new rims/tires on.
Cheers!
davev8 is offline   Reply With Quote
Unread 08-13-2014, 08:59 AM   #2
94cherry
1994 ZJ
We need more info like Engine size and what transfer case it has.
Authority should derive from the consent of the governed, not from threat of force!
94cherry is offline   Reply With Quote
Unread 08-13-2014, 10:18 AM   #3
AmishFury
his jeep info says 5.2 so we can easily assume 249 with the (relatively) low miles VC problems will depend on how the tires were maintained/replaced over the 85K
good overall recommendation is to do a fluid service on everything... oil, trans, TC, diffs, coolant that way you know when it was all done last... maybe even do new plugs/wires/cap/rotor too
AmishFury is offline   Reply With Quote
Unread 08-13-2014, 10:23 AM   #4
firsttimeZJ13
Second this! Start with all fresh fluids and replaceable parts! Fuel filter with the tune up.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline   Reply With Quote
Unread 08-13-2014, 10:40 AM   #5
T-nave
Im not sure what t-case you have but the stock case (np249) with a v8 did not have a 4 high mode. The 249 shift cover should say 4 ALL TIME, N (for nuetral), 4 L (LOW). Maybe grandma wanted a 242 or 231? lol. Either way it is common for t-cases to not want to shift with old or low fluid. Look at the back of your t-case and there will be a circle ID tag on it. Then you will know for sure which t-case you have.
9er, 3.5 IRO lift + 3/4" spacers w/ adjustable trac bars and arms, 242 swap, 285/70/17 Duratracs and some other doo dads
T-nave is offline   Reply With Quote
Unread 08-13-2014, 10:47 AM   #6
kg6mov
Hears the voices
kg6mov's Avatar
I bet he means 4 full time.
Sounds like a frozen 249 linkage to me. Grandma never used 4lo, and especially on the 249 if you don't use it you lose it.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote
Unread 08-13-2014, 02:00 PM   #7
AmishFury
Or he is trying to shift it while in gear... trans needs to be in neutral and you need to pull back hard to get it in 4lo
Unread 08-13-2014, 07:29 PM   #8
Shanebear
1994 ZJ
Neutral moving slowly, don't do it while stopped. I did it once...loudest CLUNK ever
Shanebear is offline   Reply With Quote
Unread 08-13-2014, 08:45 PM   #9
AmishFury
i was going to say i've never had a clunk or other problem shifting to 4lo while stopped but i do have the 242...
Unread 08-13-2014, 08:53 PM   #10
firsttimeZJ13
My 249 has never made noises going to 4lo stopped.
Unread Yesterday, 10:58 AM   #11
davev8
Thanks gents. Been away but I appreciate the replies. I will replace the fluids (tho all look fresh) and replace plugs/wires etc.
The TC is a 249 btw
Unread Yesterday, 04:52 PM   #12
underpowered
Bouncin' on a Budget
underpowered's Avatar
crawl under it an soak the linkage in some PB blaster and let it soak in. Should free it up.
1998 ZJ 2" bb and 31's. street queen but sees the woods once in a while.
2000 powerjoke tow pig
Anti-jeep--1989 K5 blazer. the new off road ride
underpowered is offline   Reply With Quote
Unread Yesterday, 05:01 PM   #13
jeepjeepster
Sounds bad.. Ill buy it for $1700..
1994 ZJ-I6 w/211,000 mi
1998 ZJ 5.9 w/64,800 mi Slate Black
2004 KJ w/85,000 mi
jeepjeepster is offline   Reply With Quote
