New rims - JeepForum.com
post #1 of 18 Old 04-26-2013, 12:37 PM Thread Starter
jeepinbassist
New rims
I'm looking to get new rims. I want to go with 15x8 with 3.75 bs. My question is will my tires that I have (235 75 r15) with stock rims be wide enough to fit on the new rims?
jeepinbassist is offline
post #2 of 18 Old 04-26-2013, 04:59 PM
JeepNicholson
Yes, they'll fit, but your tire guy might curse a bit when he has a bit of a hard time seating the bead, and you might have to run at a bit higher PSI, and they've got more of a chance of the bead unseating if you do any heavy offroading..and they might look like a bit like marshmallows....the tire shoulders will wear a bit more quickly than they should, too. But, yeah, they'll fit.
JeepNicholson is offline
post #3 of 18 Old 04-26-2013, 10:35 PM Thread Starter
jeepinbassist
I'll be the one changing them, hopefully it won't be too big of a PITA. Is it not recommended though?
post #4 of 18 Old 04-26-2013, 11:15 PM
dnuccio
It is less than ideal, but it will work.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 18 Old 04-27-2013, 02:48 AM
ejschultz
I had a set of 235/17/15s in my garage for about a month stacked on end. I found out that it's not a good idea to stack tires because they'll flatten each other out. I had a hell of a time getting them to seat on the stock 15x7 rims on my old Jimmy. Hopefully you don't have them stacked. That's really going to make it hard for the tire guy.
ejschultz is offline
post #6 of 18 Old 04-27-2013, 01:24 PM Thread Starter
jeepinbassist
They are on my zj right now i just want new rims but don't want to get bigger tires at the same time
post #7 of 18 Old 05-23-2013, 11:09 PM Thread Starter
jeepinbassist
Another question on rims. If I get 16" rims is there more available tires around 32"? and does it make the price of the tire go up or down?
post #8 of 18 Old 05-24-2013, 12:39 AM
jabba974
IMO...I would go with a 15x7 instead if you plan on running the 235's....Unless you have future plans of a lift and bigger tires that is....and I agree with Jeepnicholson, they will look funky on the wider rims...
jabba974 is offline
post #9 of 18 Old 05-25-2013, 10:48 PM
just_urd
I would run 15" myself. 16" rim tires are more expensive depending on the size you go with. A close equivalent to a 32" tire would probably beeee a 32x12.50 R15 or a 285/75R16...
just_urd is offline
post #10 of 18 Old 05-25-2013, 10:53 PM
just_urd
Or maybe a 32x11.50 R15... I haven't dealt with standard fitments for a few years. Mose tires are going to metric if they're larger diameter than a 15" wheel, for SUVs and trucks that is...
just_urd is offline
post #11 of 18 Old 05-27-2013, 02:50 AM Thread Starter
jeepinbassist
I have the lift on now I'm just saving up for the tires but i want to know what to get
post #12 of 18 Old 05-27-2013, 02:52 AM Thread Starter
jeepinbassist
Would the price if the tire go down because there us less rubber with a 16
post #13 of 18 Old 05-27-2013, 06:34 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
No
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #14 of 18 Old 05-27-2013, 12:08 PM Thread Starter
jeepinbassist
Ok. Is there a larger variety for large tires on a 16" rim?
post #15 of 18 Old 05-27-2013, 12:51 PM
ejschultz
After shopping around a lot for tires for my stock TSi 16" rims, I ended up buying a set of 15s and tires for them. Tires are cheaper for 15s and there are more options available. I think the next time I need tires, the cost of the 15s will be a wash and every set after that I'll be "coming out ahead."
