New Rear shock mounts 2004 WJ - JeepForum.com
post #1 of 9 Old 05-06-2009, 04:54 PM Thread Starter
AL04WJ
Kevin's off road says the 2004 WJ requires different rear shock mounts when replacing stock shocks with aftermarket shocks. I am ordering the IRO 3" lift soon and was wondering does it come with new rear shock mounts?
Also IRO says there may be occasional rear shock contact that most people choose to ignore. I plan to run 265/75/R16 goodyear wrangler duratracs on the stock rim with 3'' bumpstops and Rancho RS9000XL's, should I have a propblem with shock contact? I do not want to tear up new expensive rancho shocks.
Julian
2004 Laredo 4" lift, 265/75/16 Duratracs, JCR Stage II sliders, ARB bumper and XD9000
AL04WJ is offline
post #2 of 9 Old 05-06-2009, 05:26 PM
hike4it
Buy some spydertrax wheel spacer
hike4it is offline
post #3 of 9 Old 05-06-2009, 05:45 PM
GraKee99
Rapist Wit
GraKee99's Avatar
The KOR rear shock mount kit is for the rear shock bushings. If your rear shocks clunk they are suppose to fix that problem. I have them and have no rear clunks.
As far as tires rubbing the shocks, only way to find out is to flex it out and see if they rub. If they do, you need to get spacers or different wheels.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 9 Old 05-06-2009, 05:51 PM
blovingier
blovingier's Avatar
I'm at 3" with 245/75/16 tires on stock rims and I am really close to rubbing at about 50-75% flex. I haven't had a chance to get it flexed all the way out yet. I would say that you should contact IRO and see if they send a similar kit to the one from KOR. If not, then get the shock mount kit just in case, it's only $20. Send Kolak a PM and he'll take care of you.
"GRITZ"
99 Jeep Grand Cherokee Laredo - Totalled
-3" lift w/Bilsteins - - - - - - - - - - - - - - - - - -30.5" Pirelli Scorpion ATRs
07 Compass (wife's ride)Sold
-Stock
blovingier is offline
post #5 of 9 Old 05-06-2009, 10:25 PM Thread Starter
AL04WJ
I'm just curious if my tires will hit my rear shocks more often because I'm getting RS9000XL's instead of the shocks IRO offers. Wheel spacers can be added later faily easily right?
Julian
AL04WJ is offline
post #6 of 9 Old 05-07-2009, 06:53 AM
blovingier
blovingier's Avatar
Wheel spacers are as easy as changing a tire. You'll need a torque wrench though. I know my tires are close. Just try it and see what happens.
"GRITZ"
-Stock
post #7 of 9 Old 05-07-2009, 08:26 AM
GraKee99
Rapist Wit
GraKee99's Avatar
If he is installing the lift or ever working on a vehicle, a torque wrench should be a common tool to own.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #8 of 9 Old 05-07-2009, 03:10 PM Thread Starter
AL04WJ
Yes, I have a torque wrench.
Julian
AL04WJ is offline
post #9 of 9 Old 05-07-2009, 04:01 PM
blovingier
blovingier's Avatar
You are correct, but I did the guessing thing for quite some time. I now have three and use them more than I ever thought I would. I think craftsman has their torque wrenches on sale again, so I may buy another to keep in the Jeep or something.
"GRITZ"
-Stock
Rear Shock Mounts - KOR Bushing Kit JustSomeDude ZJ Grand Cherokee Forum 8 04-22-2009 12:46 PM
2004 Gr Cherokee Shock Problem cultcab ZJ Grand Cherokee Forum 4 04-06-2009 08:08 PM
KOR Shock mounts? G-Wagon00 ZJ Grand Cherokee Forum 11 05-19-2008 02:06 PM
bolt grade wj shock absorber mounts gpJeep ZJ Grand Cherokee Forum 1 09-21-2006 10:24 AM
Modified front lower shock mounts? ZJenvy ZJ Grand Cherokee Forum 29 11-18-2005 05:30 PM
