Is New Rear Main Seal Bad Already? - Page 2 - JeepForum.com
post #16 of 23 Old 03-28-2014, 10:25 PM
davidtownsend
2006 WK
Originally Posted by 90Notch306 View Post
If there is that much oil already then i would say it was a improper installation. However, i did a rear main seal on my 5.2 and it still leaked oil. Recently pulled the transmission and noticed the oil leak was coming from the camshaft plug. Replaced the plug and put some sealant on it and the leak is gone now
Don't mean to jack this thread but I did my rear main myself and i put the seals in the right way and it still leaks. I changed my oil pressure sensor and valve cover gaskets so I'm thinking it's this camshaft plug. Do you have any pictures?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #17 of 23 Old 03-31-2014, 08:41 PM
90Notch306
I do not have any pictures but once you pull the trans you'll see it right in the middle. I also changed the freeze plugs while I was there so I didnt have to pull the trans a second time
90Notch306 is offline
post #18 of 23 Old 03-31-2014, 09:11 PM
davidtownsend
2006 WK
I might had had to do this. I really don't want to pull though. Thank you!
post #19 of 23 Old 07-15-2014, 05:27 PM
GeneralTJWillys
Just had engine in my TJ rebuilt due to a poor oil pan install after new oil pump was put in. Wheeled the following weekend and sandy water flooded the pan past an improperly installed pan gasket. Yes...liquid sandpaper throughout the engine.
So now...the engine runs perfectly again BUT...I have a major leak at the rear. Swapped the new DNJ main seal with a better Fel-Pro seal. SAME leak...major. Also checked for leak from valve cover and all other usual suspect places. All bone dry.
Now I am in process of pulling the TRANSMISSION and am going to check the rear block plugs. Once trans is out...since I can't start it...I will pull the OPDA and run a priming rod with my 3/8 drill and eyeball the rear of the block to see what gives.
Wish me luck and free beer deliveries. I may need plenty of both before it's over! And I will post my findings.
JEEP.........Gecko of the automotive world!!
Constitutional, Independent, Conservative leaning, gun toting crazy American patriot!! WATCH OUT!!
GeneralTJWillys is offline
post #20 of 23 Old 07-15-2014, 06:04 PM
jay-h
Originally Posted by PHARIS88 View Post
So drove the Jeep 40 miles round trip to work and back.. and no LEAKS! HOWEVER!!! My oil pressure gauge will run at about 40-45psi going down the highway at 65mph... (WHICH I KNOW IS NORMAL). BUT I have been paranoid that something is wrong, b/c before the new tranny, new rear main seal, after the new oil pan gasket, and new oil filter.. my pressure gauge seemed to ALWAYS be at 40 and rarely went above or below it. NOW the gauge will go all the way down to about 18-20... Oil light doesn't come on and I'm not leaking oil (as of right now) lol
I researched the threads about "normal pressure" and some threads say it's normal some say I need a motor ha
Sound normal to you?
There is some truth to that. Exact pressure is not important. If you pressure starts dropping (under comparable conditions) is the more significant issue.
My ZJ (which I consider a clean, healthy engine) holds about 40. My 258 will run about 60 at speed.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #21 of 23 Old 07-16-2014, 01:54 AM
AVR2
Factory spec for the oil pressure only gives minimum acceptable readings, so as long as you're above those, you're OK. The 4.0L should have a minimum of 13 psi at idle, and 37 psi at 1600rpm or above.
AVR2 is offline
post #22 of 23 Old 07-17-2014, 08:16 PM
Scrubberguy
10 pounds per 1000 RPM was what I was taught during racing days.
Scrubberguy is offline
post #23 of 23 Old 07-25-2014, 03:58 PM Thread Starter
PHARIS88
That sounds about right, since I fixed everything it will idle around 13psi and get all the way up to 45-50 depending on the speed
Anybody can be become an American, you have to be BORN TEXAN!
PHARIS88 is offline
