Quantcast new rear LCA's, now clunky clunk from rear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > new rear LCA's, now clunky clunk from rear
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 04-11-2009, 02:14 PM   #1
dmolaver15
i put IRO lower adjustables on the rear yesterday, today i noticed it clunks when power is applied or i take my foot off the gas, the clunking coming from the rear end.
i'm thinking the pinion angle is just thrown off, i just made the control arms about an inch longer than stock and threw them on. with the stock arms the pinion angle was perfect, should i just make them stock length?
04 WJ 4.0
6.5" IRO Front and Rear Longarms
Soft 8's, 285/75/16 BFG Mall Terrains
Super 44 with 3" Side Dump
Dana 44a, 4.56's
My Build Thread: http://www.jeepforum.com/forum/f197/evolution-my-wj-623825/
dmolaver15 is offline   Reply With Quote
Old 04-11-2009, 02:18 PM   #2
StrokedWJ
Whats the pinion angle now? Do you have the A-Arm spacer also? These are long arms or short? (I'm guessing short, but your sig says IRO LA's)
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Old 04-11-2009, 04:02 PM   #3
skain8
Not to be an ***, but if your pinion angle was "perfect" with your stock arms, why did you i) get adjustable rears and ii) make your adjustables an inch longer?
'02 WJ: 4.7L, 5", 231HD w/SYE, 35's, Clayton's, locked, chopped & armor
'06 XK: 65th Anniversary Edition
'98 XJ: Stolen
www.endlessmtnfab.com
skain8 is offline   Reply With Quote
Old 04-11-2009, 10:33 PM   #4
dmolaver15
i got the adjustable rears because i'm going up to 6.5" of lift soon, and was planning on running it on short arm adjustables for a while, but then i got a deal on a set of rear longarms, so when they come in is when i'll go up to 6.5". and i made them an inch longer because i wanted to get my tire away from the inside of my fender, but i didnt take into consideration the bad pinion angle that would cause
i'm going to make them just as long as the stock ones, and then see if the clunking goes away tomorrow
04 WJ 4.0
Dana 44a, 4.56's
My Build Thread: http://www.jeepforum.com/forum/showthread.php?t=623825
Old 04-12-2009, 12:11 AM   #5
RrCoX22
if you don't have adj. uppers... your pinion angle won't be happy although normally the lowers just move the axle back and forth but it also has an effect on pinion angle due to that
[FONT="Impact"][SIZE="3"]1997 5.2L [COLOR="Red"]ZJ[/COLOR] [COLOR="DimGray"]Limited[/COLOR][/SIZE][/FONT]
[URL="http://www.norcal4x4forum.com"]Norcal 4x4 Forum[/URL] | [URL="http://www.fquick.com/RrCoX22"]My Garage[/URL]
RrCoX22 is offline   Reply With Quote
Old 04-12-2009, 12:15 AM   #6
AgitatedPancake
Frobot Fabrication
AgitatedPancake's Avatar
There are no uppers on a WJ =P Just the A-arm, which you get a spacer to adjust.
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake is offline   Reply With Quote
Old 04-12-2009, 12:16 AM   #7
BlackShuck
^^^If you're selling the adjustable short arms when your long arms arrive, I'm interested.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline   Reply With Quote
Glock Forum
