New project Speed bumps! - JeepForum.com
post #1 of 7 Old 11-14-2010, 12:17 PM Thread Starter
Jacobjeep
I just inherited a 1995 zj 4.0 very clean! but the engine has water in oil and transmission does not want to shift?
#1 I have looked around head gasket and it appears to be in good shape what else could put water in oil? anything? could be head gasket still just wondering?
#2 The transmission does not like to shift it will shift into 2nd fine but then it takes an act of god to get into 3 or 4. there is a small amount of metal flake in tran pan but seems to be fine. ( when put into drive it goes into gear fast and feels like it wants to go? maybe related?)
Jacobjeep is offline
post #2 of 7 Old 11-14-2010, 01:01 PM
MoparBoy01
I had the same issue you did with question #2. I had a small amount of flakes in the trans pan but it looked good. I changed the trans fluid and filter and now shifts fine. I dont know how to answer questions #1 though, I have never really had that problem. Have you changed the oil lately?
1998 ZJ 4.0L-Trail Rig
1998 ZJ Black 5.9L-Prerunner/Daily Driver
1999 XJ 4.0L-Daily Driver/sometimes a weekend warrior
Down and Dirty Offroad Club Member
ddoffroad.com
MoparBoy01 is offline
post #3 of 7 Old 11-14-2010, 01:08 PM
Newb1995jeepgc
1994 ZJ
Your TV cable might need adjusted, that should help your shifting issue, and for the water issue in the oil, do you have Coolent in your Radiater or Water? If you have water in your oil and coolent in your radiater then its not a head gasket problem, it may had just had water in the oil from some other reason that hopefully wont happen again. Hope you get your problems worked out on your ZJ.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #4 of 7 Old 11-14-2010, 01:38 PM Thread Starter
Jacobjeep
I have adjusted tv cable its really not the same as that, I will change filter and fluid...
the oil was changed and it immediately was contaminated ? is there a plug or something by the water pump?
post #5 of 7 Old 11-14-2010, 04:32 PM
biggoofy
head gasket
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #6 of 7 Old 11-14-2010, 04:47 PM Thread Starter
Jacobjeep
I hope
post #7 of 7 Old 11-15-2010, 12:04 AM
JesseOR
COMPRESSION TEST TIME!!!!
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
42re , jeep , problems , shift , zj
wk seems to shutter/clunk whenever i go over bumps? arc11 WK Grand Cherokee & XK Commander Forum 2 08-11-2012 07:51 AM
Rear end stiff over bumps? 00Limited ZJ Grand Cherokee Forum 9 06-18-2009 09:12 PM
Clunk Over Bumps eking511 WK Grand Cherokee & XK Commander Forum 8 09-09-2008 06:13 PM
DW after I hit bumps on a 93 ZJ... ck4x4 ZJ Grand Cherokee Forum 7 06-27-2008 06:49 AM
Bumps stops Swamp Boy ZJ Grand Cherokee Forum 2 02-27-2003 10:16 PM
