New power steering pump and pressure hose, now excessive pump noise - JeepForum.com
post #1 of 15 Old 03-02-2008, 06:57 PM Thread Starter
Jeeples
Jeeples's Avatar
So I replaced the power steering pump and the high pressure hose on my fiance's Jeep. The old pump had a small crack in the resevoir and the pressure hose leaked on the pump side fitting as well.
Aside from not having the fan clutch side of the pressure hose completely tightened, everything went pretty smooth. Immediately upon start up there was a lot of pump noise, which quieted down a bit after the fluid circulated throughout the system. However there is definitely a good amount of noise coming from the pump, higher RPM's and turning to full lock only makes the sound worse.
I'm no stranger to working on cars, and to me it sounds a lot like a bad bearing in the pump, and it certainly is possible to have purchased a bad unit straight out of the box. I wanted to make sure I used the right fluid, so I originally purchased some from the local dealer.
My only concern is that in the past, other dealer's have given us the MOPAR Power Steering Fluid +4 to use, and it had worked just fine. This time however the dealer gave me MOPAR branded power steering fluid. Even on the back of the bottle is says for use in 2004 and older Jeep Grand Cherokee's, and 1998 and older Chrysler vehicles.
I would much rather flush the system then go through and order a new pump and swap it out. Which is the correct fluid to use? Any other thoughts on what this could be?
Thanks!
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #2 of 15 Old 03-02-2008, 07:17 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I remember that when changing a P/S pump and reservoir a long time ago, I had to cycle the steering both ways a couple of times while adding fluid to eliminate the bubbles.
It could still have some air in the system, since you disconnected all the lines, the fluid leaked all out from it.
At full steering lock they always make noise, some more than others.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #3 of 15 Old 03-02-2008, 07:23 PM Thread Starter
Jeeples
Jeeples's Avatar
Right, I understand that the pump will be noisier at full lock, but this sounds like a resevoir full of marbles, definitely not the 'strained' pump noise that is common at full lock.
Perhaps I'll drain the system again and try turning the wheels while adding fluid. I simply topped off the resevoir and with the wheels off the ground, turned lock to lock 10 times upon initial startup.
Jeeples is offline
post #4 of 15 Old 03-02-2008, 07:31 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Maybe there are some marbles inside....
You sure nothing dropped in there...
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
post #5 of 15 Old 03-02-2008, 07:32 PM
Upside
You need to bleed the system. Most shop manuals require you to turn the wheels lock to lock 40 times with the wheels off the ground as a bleeding procedure. Any air in the system will cause a lot of noise.
On one vehicle I had a noisy pump that wouldn't quiet down no matter what I did so I ended up replacing it with another new one.
Upside is offline
post #6 of 15 Old 03-02-2008, 08:04 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Any power steering fluid will work just as well as Mopar stuff.
It might appear that you purchased a bad “new” pump. Turning the wheel both directions many times, is a necessary as Upside stated. I do this with the engine off and the vehicle jacked up and the cap off the reservoir.
My power steering reservoir has a fine crack in it as well (for the past year now)
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 15 Old 03-02-2008, 08:05 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I believe mine has a crack too, since It leaks and have not been able to find where from.
Not to highjack..
Just as a curiosity, is there another steering box that can be used as a chep upgrade for the stock ZJ.
I'd like to get rid of some play, and at the same time upgrade a bit if possible.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
post #8 of 15 Old 03-02-2008, 08:42 PM
greasefingers
1994 ZJ
Mine leaks at the seam of the two halves, if that helps.
Cheers Steve
post #9 of 15 Old 03-02-2008, 11:43 PM Thread Starter
Jeeples
Jeeples's Avatar
Ok, I'll give that a shot tomorrow, hopefully I just didn't get the system bled very well.
I figured as much once I saw the MOPAR spec rating on the bottle, but like I said, I had been given the MOPAR Power Steering Fluid +4 from a different dealer, which made me concerned about the fluid type.
I'm still hoping that the system just needs to be bled, but if I have to, I can pickup another pump under warranty.
Jeeples is offline
post #10 of 15 Old 03-02-2008, 11:46 PM Thread Starter
Jeeples
Jeeples's Avatar
Her's had a small crack on one of plastic nipples for the return line, most likely caused when the fluid was last serviced. It was also leaking from the pump side fitting on the high pressure line, which MOPAR fixed with an updated pressure hose.
I wouldn't have messed with it, if it wasn't for the fact the leak was getting progressively worse.
Jeeples is offline
post #11 of 15 Old 03-03-2008, 07:13 AM
JayJEEPguy
JayJEEPguy's Avatar
Are you sure you don't need the special hydraulic fluid/power steering fluid? My '04 calls for it due to the hydraulic fan setup.
It cost a few dollars more per quart. I believe the part number is listed on the www.wjjeeps.com website.
Jason T.
'99 GMC Suburban: Gas-guzzling people mover with 18" Z71 wheels
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hear
JayJEEPguy is offline
post #12 of 15 Old 03-04-2008, 06:03 PM Thread Starter
Jeeples
Jeeples's Avatar
I called up a couple dealers and talked with a couple different techs, they all confirmed that standard MOPAR Power Steering fluid is what is required, regardless of the style of cooling fan.
The vehicle sat overnight and I double checked for leaks, after taking it for a short ride on some nearby roads, everything is nice and quiet. I assume the system wasn't completely bled and that's where my pump noise was coming from.
Went ahead and replaced the serp belt as well, since it still had MOPAR numbers written on it.
Jeeples is offline
post #13 of 15 Old 03-04-2008, 06:17 PM
greasefingers
1994 ZJ
If the power steering fluid is coupled to the hydraulic fan, which mine is not, then I would absolutely stick with the OEM stuff; as mixing fluid types in this situation be detrimental! I did not realize the some Jeeps did this. Thanks, Jeeples, for pointing this out. The common sealed (and not shared) hydraulic or viscous-coupled fan, has silicone oil in it.
Cheers Steve
post #14 of 15 Old 03-15-2011, 03:29 PM
VTZJ
Originally Posted by Jeeples View Post
So I replaced the power steering pump and the high pressure hose on my fiance's Jeep...Immediately upon start up there was a lot of pump noise, which quieted down a bit after the fluid circulated throughout the system. However there is definitely a good amount of noise coming from the pump, higher RPM's and turning to full lock only makes the sound worse.
Was this a rebuilt pump from a parts store by any chance? I have been disappointed with the rebuilt units (like James Dean, they live fast and die young). Next time I replace mine, I'm pulling one from a boneyard ZJ with a tow package.
96 ZJ 4.0, 42RE, NV242, Dana30/35c w TruTracs, stock height and tires, MM12k hydraulic winch on Hanson bumper, some armor.
VTZJ is offline
post #15 of 15 Old 03-15-2011, 03:59 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Have had some problems with cardone. Resevoir leaked on first one. Wound up getting one without a resevoir and using my old one. Also I would run it awhile and take a suction gun and pull some of the fluid out ,putting in new until the fluid stays clean. My gearbox had some nasty in it.
coralman is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
96 GC power steering pump noise jetdude ZJ Grand Cherokee Forum 3 12-13-2009 06:10 PM
01 4.7 pwr steering hose line pump to cooler philly3384 ZJ Grand Cherokee Forum 1 06-23-2009 11:47 PM
Power steering pump making horrendous noise. Dumb question, but.... KingPrat ZJ Grand Cherokee Forum 10 03-03-2008 05:15 AM
Power Steering Pump Noise Death-Mobile ZJ Grand Cherokee Forum 4 08-12-2006 08:09 PM
