New Owner help - JeepForum.com
post #1 of 4 Old 10-03-2006, 08:22 PM Thread Starter
revo1059
New Owner help
Ok, just picked up a 00 GC Limited with 120k on the ODO for a winter car. Just had rear diff rebuilt, what else should I keep an eye out for. So far, this vehicle has NO leaks on any kind and seems to run OK. All of the gadgets seem to be working. Looking to find the common issues/problem with this vehicle.
Also, are there any interesting mods that I can do without spending lots o' $ (NO plans to off-road). I know very little about GC's and am just trying to get my feet wet learing about them.
revo1059 is offline
post #2 of 4 Old 10-03-2006, 08:30 PM
dpthomasjr
dpthomasjr's Avatar
congrats on the new purchase. i have a 99 with 105k. i have replace all fluids many times.
THings i have replaced.
oil pressure sender
rear output shaft seal (leak)
transfer case grommet on top of case. (leak)
fuel pump/relay
cooling fan/relay
nothing major.
As far as basic mods. Maybe the rear addco sway bar to help reduce the "body roll" on turns.
2010 JK Wrangler Unlimited Sahara
Previous Jeeps:
2001 XJ Cherokee Limited
1999 WJ Grand Cherokee Limited
dpthomasjr is offline
post #3 of 4 Old 10-03-2006, 10:07 PM
micifus
Original GC'er
micifus's Avatar
Keep up on all the fluids and use the right ones, doesnt hurt to ask here first before doing and sort of preventative maintance/fixing. Crawl under your jeep once a month and watch for for fluids leaking odd noises. Welcome BTW there is more info here then you will ever need.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #4 of 4 Old 10-04-2006, 09:50 AM
GrandchampWJ02
2006 WK
You might want to start reading www.wjjeeps.com too. That site has more about the vehicle as a whole including part #'s for most things than you will find anywhere else. I spent hours poking around that site when I first got my WJ.
My Cheap mod suggestion: 2" Budget Boost will run you around $100 and its easy to install. Get 2" higher without breaking the bank and keep suspension stock. I know you said you won't be going offroad but it makes the WJ look so much better than stock.
--Reid
'06 WK Laredo 4.7 Light Khaki
Colorado Jeep Club Member #36
Previous Jeeps:
'02 Black WJ Laredo 4.7, '96 Cherokee Classic Moss Green
GrandchampWJ02 is offline
New ZJ owner Bandit84 ZJ Grand Cherokee Forum 1 05-09-2008 10:11 AM
New CRD owner here roadman WK Grand Cherokee & XK Commander Forum 15 04-12-2008 01:21 AM
New WJ owner matt21484 ZJ Grand Cherokee Forum 9 03-26-2008 02:10 PM
New Owner Maybe, What to look for?? Green 99GCLtd ZJ Grand Cherokee Forum 8 09-15-2006 12:48 PM
New Owner! devilfish ZJ Grand Cherokee Forum 3 09-05-2006 09:36 PM
