New Member, First Problem - JeepForum.com
post #1 of 8 Old 02-23-2008, 04:55 PM Thread Starter
grover175
I just bought a 96 GCL, And I am doing some little things that needed done. I changed the struts on the rear hatch, and now I cant get it to open. I will pull hard, I've had someone outside while I push from inside.. Any suggestions.. ?? Thanks
grover175 is offline
post #2 of 8 Old 02-23-2008, 05:14 PM
haumana
kickin' it in the VOG!
haumana's Avatar
to the forum!
Does the hatch even give a hint to movement, or it is shut solid like it was locked? How is the tension on the hatch handle (is there resistance as if it wanted to unlatch, or is there no resistance like when it's locked)?
'00 Laredo / 4.7 / QD / stock, stock, stock .. with brand spankin' new tires! [It's a REAL Jeep]
'98 Laredo / 4.0 I6 / 2WD (no laughing!) ... SOLD.
'96 Limited ... completely totaled and taken to the bone yard.
haumana is offline
post #3 of 8 Old 02-23-2008, 05:23 PM
Vestjam
I thought there was something up in the Faq's, but I couldn't fine it.
This is not an uncommon problem. Open the rear window and remove the four top screws that hold the rear panel in. Then you'll need to pry the panel out just enough to see the locking mechanism at the bottom. Don't pull to hard or the panel will crach. I stuck a piece of 2x4 in between the panel and the hatch so I had both hands free. With a flash light, look down at the lock mechanism. I then cut the top of a hanger off and stretched it out into a long staight line. I made a small U shape at one end. I guided the 'U' end down to the locking mechanism and once I captured the lever, I pulled up and released the lock. When the hatch opens, remove the rest of the panel. There will be some hidden screws in the bottom carpeted corners. Feel for them. Once the panel is off, the locking mechanism will be exposed. You will see a threaded rod that is attached to the handle. That rod is captured by a metal clip. The clip looses grip on the screw rod and slips. That's why the door won't open. Adjust it until it functions properly. I used some safety wire to wrap around the screw rod once I had the adjustment correct. That will prevent the rod from slipping in the future.
Good luck.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #4 of 8 Old 02-23-2008, 05:26 PM Thread Starter
grover175
It's got just a little movement, barely, feels unlocked, And after I pull on it, If i push it, I can hear it click.. Seems like a bind, But I cant see where it would be binding..
post #5 of 8 Old 02-23-2008, 05:28 PM Thread Starter
grover175
It's a one piece hatch, can't open window.. lol, Can i still use a nifty trick form the inside?
post #6 of 8 Old 02-23-2008, 06:29 PM
Vestjam
yes, but you will need someone either watching from the outside to guide you. I know some folks have just cut a 4x4 hole in the center bottom of the panel and exposed the lock mechanism. Then you can either replace the panel later or cover it up...
Have patience.... you can do it.
Vestjam is offline
post #7 of 8 Old 02-24-2008, 07:19 PM Thread Starter
grover175
Hey thanks a bunch, Popped it with the hanger, adjusted the thingy.. and It works like a dream...
I can already see that this place is gonna be a great place to be..
post #8 of 8 Old 02-24-2008, 07:46 PM
Vestjam
.... and the satisfaction of doing it all yourself is priceless.
Vestjam is offline
new member immobiliser and transmission problem general--lee ZJ Grand Cherokee Forum 4 04-08-2010 10:02 AM
new forum member with 4x4 problem ajamie ZJ Grand Cherokee Forum 11 06-11-2007 08:54 PM
New Member caboboy ZJ Grand Cherokee Forum 20 04-17-2006 09:15 PM
New member..and yes, I have a tech problem.. SgtB ZJ Grand Cherokee Forum 2 11-30-2005 07:38 AM
Hello All, new member, common problem? ///BHRpowered ZJ Grand Cherokee Forum 13 04-22-2005 02:41 PM
