new to me zj :) starter problem ? - JeepForum.com
post #1 of 18 Old 05-22-2011, 08:18 PM Thread Starter
chazharris97tj
Just bought myself a 93 zj 5.2 laredo. It's pretty clean needed a cleaning and the hood and bumper needs painted. Picked it up for 450 cuz it wouldn't start at first. Got it started and drove to my shop. Now it won't start just cranks and cranks. I think I flooded it gonna try it later. Would that be the starter?
chazharris97tj is offline
post #2 of 18 Old 05-22-2011, 08:32 PM
freakinheep89
if its cranks and cranks like you said then its not the starter.
most likely the crank sensor, test for spark at the coil
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 18 Old 05-23-2011, 11:39 AM Thread Starter
chazharris97tj
I'll have to check that. It's been sitting for overs year. It was out of gas put 1 gal in this morning and it started then died. Maybe it burned a gallon starting?
post #4 of 18 Old 05-23-2011, 12:53 PM
freakinheep89
Theres no way it could burn a gallon in such a short time.
Sometimes you need a little more than a gallon to reach the fuel pump pickup. go get a 5 gal gas can and throw 5 gal in and see what happens.
TJ-
post #5 of 18 Old 05-23-2011, 01:37 PM Thread Starter
chazharris97tj
Will do
post #6 of 18 Old 05-23-2011, 04:26 PM Thread Starter
chazharris97tj
So when I turn the key there is one single click and that's all. It won't even crank now. I have power to everything it just won't start just clicks
post #7 of 18 Old 05-23-2011, 04:27 PM Thread Starter
chazharris97tj
It's also saying service 4wd switch.
post #8 of 18 Old 05-23-2011, 04:32 PM
1stblack97ZJ
FWIW the service 4wd switch has nothing to do with your starting issue.
I'd check the coil.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #9 of 18 Old 05-23-2011, 04:52 PM
freakinheep89
If it just clicks when you turn the key then the battery is dead.
I would say after sitting up for years the battery is probably shot
TJ-
post #10 of 18 Old 05-23-2011, 09:57 PM Thread Starter
chazharris97tj
its a brand new battery. everything has power. im gonna get the starter tested tomorrow. and add some gas to it.
post #11 of 18 Old 05-23-2011, 10:40 PM
Canyon411
Sounds like the solenoid on the starter might be toast. Might as well replace the starter with a fresh reman with a lifetime warranty while you are at it. I would throw a charger on that new battery in the meantime. It may be new, but cranking over and over may have toasted the starter as well as worn the battery down to a low voltage as well.
Canyon411 is offline
post #12 of 18 Old 05-23-2011, 10:40 PM
phitmein
phitmein's Avatar
try hitting the starter a couple of times with a hammer and try to start it ...
Clean your battery connections and check the pos. wire where it goes to the starter ...
Have someone try to start it in the dark and see if you see a spark jump where there might be a bad connection ...
Don't rule out that it isn't a battery problem yet ...
Turn on your bright lights for a minute or so and see if they get weaker ...
Phit
phitmein is offline
post #13 of 18 Old 05-24-2011, 08:32 AM
Midnightluckey
Well have you charged the battery back up since you were cranking and cranking it? It's possible you just drained it trying to start it this whole time? Even if it isn't enough to turn it over, it can still let the lights work fine. Try using the power windows and see how fast they move, if at all.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #14 of 18 Old 05-24-2011, 04:14 PM Thread Starter
chazharris97tj
Just had the starter tested and it was bad. It was the factory one so no wonder it was bad.
post #15 of 18 Old 05-24-2011, 05:13 PM
Midnightluckey
Pfft. You only got 18 years out of your starter? What a pos.
