So on my limited 01 wj. I put in the Teraflex long arm kit with the 4" lift. Took me quite a while and when I can upgrade this account, Ill post pictures.
But the brake lines are somewhat tight and I'd like to get new ones. Anybody know exactly what I need?
Also is there any option for a grille gaurd since the unibody construction? Or what are my options? Id like to mount some nice lights on it.
Pics to come!
(I hope)
*Notes on teraflex kit*
It was a gift from my father, who had no real idea about lifts. Nor did I. The kit comes with a pitman arm lowerer, and a trackbar lowering bracket. As soon as I can I'm going to ditch both and go with a JKS adj trackbar.
I also just bolted the read and front long arm brackets to the unibody, but since I did opt to put in the TC lower kit, I'm going to for sure get the front brackets welded asap. The rear ones should be okay, I used 3 grade 8 bolts and hopefully will be fine.
Right now I'm just looking into the brake lines, I know people say you don't need extensions, but I'm going to upgrade to the best lines available since I need to bleed them anyways.
Things to look for in the future: New upper control arms.
