new to jeeps! deal or no deal? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > new to jeeps! deal or no deal?
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 04-03-2012, 09:12 PM   #16
gabrod72
Originally Posted by honda471 View Post
Your rear tail lights are pretty ugly. If you want, I'd trade them to you for some stockers...
Hell I figured I'd give it a shot. They actually look pretty neat.
gabrod72 is offline   Reply With Quote
Unread 04-03-2012, 09:19 PM   #17
honda471
I was a big explorer v8 guy an saw this jeep for the price an pretty much sold it for nothing to get this I love the interior layout, I like the roof rack, but I need to figure what kind of damn rims those are the center cap has ar on it so I searched american racing an didnt see any one of the rims is a soft 8 not really noticeable, but could hurt the jeeps an my sex appeal lol
honda471 is offline   Reply With Quote
Unread 04-03-2012, 09:19 PM   #18
gabrod72
Originally Posted by jtackerman28 View Post
I had same problem was the front o2 sensor shorting out.
Actually this makes more sense than what I posted. I went back and read the description again and realized I missed the part where it would shut off.
Unread 04-03-2012, 09:21 PM   #19
honda471
Any tips on a inch or two more lift? Explorer have yorsion bars and leaf springs, im new to coils.
Unread 04-03-2012, 09:25 PM   #20
honda471
Does that seem curable for the pot hole wabble as well? Thought my tie rod had fallrn out lol
Unread 04-03-2012, 09:29 PM   #21
gabrod72
Could do many different things with these. If you just want to keep it cheap, you can do a 2" budget boost. Look at the faqs so you can figure out what has worked for others. Once you get above that, there are several mandatory parts that are needed. Then there's getting above 4.5" which really should have long arms.... There's also what some cheap lift kits with two springs do. It's called a front to rear coil swap so you use your fronts on the rear to get around 3~4 inches.
If you're looking for something simple, keep it on the 2" BB. Whatever you do, don't smoke the crack they offer you when anyone says you can install 3" or 3.5" BB pucks without having to add all the other parts a proper lift will include. The amount of parts you need become more and more important as you get above 2".
Unread 04-03-2012, 09:38 PM   #22
honda471
Sounds like I'm staying at 2" lol im averaging bout 16.4 mpg good or bad?
Unread 04-03-2012, 09:45 PM   #23
gabrod72
Sounds about right no matter which engine you have either the 5.2 and 4.0. You may want to fill out your profile information with all the info about your vehicle. This way when you start a new thread, people can see what you have and make reasonable guesses about what to look for.
Back to the 2"... If I were doing it, I'd actually spend money on a front adjustable trackbar to make sure the axle is centered after the install. Skip the shocks instead for now and run the stock ones until they crap out, but start saving for them. This way if you end up wanting to go higher all of sudden you won't need shocks again.
Unread 04-03-2012, 09:51 PM   #24
hdrocknroll
Interesting screen name you selected for this forum
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote
Unread 04-03-2012, 10:02 PM   #25
honda471
I race motocross, all hondas, my numbers 471, only got one yammi an thats for the two stroke classes I run, an thanks I will fill that out, yeah I felt as if driver side tire stuck out a little further, it already has a 2" BB. Shocks were next on my list, or lights for the roof rack.
Unread 04-03-2012, 10:56 PM   #26
honda471
Here's this question, how do I figure out if its the 02 sensor?
Also I have a flo master turn down, how would this do on my jeep? Or would I just have a can of bumble bees?
Unread 04-04-2012, 06:35 AM   #27
jtackerman28
I run a flomaster and like of. Also UN plug both sensors and unhook negitve battery go reset pcm then drive around with them UN hooked see if your problem OS gone.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline   Reply With Quote
Unread 04-04-2012, 08:45 AM   #28
honda471
I unhooked the negative and held the brake in for about a minute and a half. Also I only found one o2 sensor and no hook ups or anything for a second o2 snsor....
Unread 04-04-2012, 08:51 AM   #29
sebian
93-95 only have one O2 sensor pre-cat.
For the wobble, sounds like Death Wobble. Someone has already mentioned to check the trackbar, and control arm bushings. That will get ya in the right direction for possible causes.
1995 ZJ 5.2L V8 318. 200,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline   Reply With Quote
Unread 04-04-2012, 09:01 AM   #30
honda471
If I did this right, the o2 sensor is not the problem
