New heater coil woes - JeepForum.com
post #1 of 1 Old 10-11-2009, 09:05 PM Thread Starter
bobiam
Had the heater and evaporator replaced on my '95 ZJ. Heater coil was fine but figured that it would be good to change it when the mechanic was in there to change the evaporator coil.
However, now that the weather is getting colder in New England, I am noting that the heat just isn't up to par. Sounds the same, controls appear to work correctly. The mechanic did glue new foam seals onto the blend doors as theirs was all faling off.
Car engine coolant temp is good where it should be. No kinks in heater feed hoses. Any ideas for me????
Thanks, Bob
'95 ZJ 5.2 V8
bobiam is offline
Heater coil or HVAC problem? Drysdale ZJ Grand Cherokee Forum 7 01-10-2010 06:53 PM
Heater/Driver seat heater lamar2626 ZJ Grand Cherokee Forum 4 11-05-2009 06:34 AM
Heater 1 of 2 heater blowers stays on 1993 GC Rocker-Mtl ZJ Grand Cherokee Forum 3 11-02-2009 10:42 AM
Heater Coil Concern Brandle ZJ Grand Cherokee Forum 3 02-04-2009 04:17 PM
AC Woes Darth Mostly ZJ Grand Cherokee Forum 7 11-29-2008 02:10 PM
