New headlamp assembly install broke adjuster - JeepForum.com
post #1 of 22 Old 04-29-2013, 09:56 AM Thread Starter
Uniblurb
Uniblurb's Avatar
I should have known better than to believe this crock-of-chit description, "OE-comparable mounting provision ensure drop-in precise fitment", on the below headlamp assembly. Guess you get what you pay for but thought $35/each w/lamp would be better than some of the cheaper ones. And $106 at the dealer is the typical outrageous priced.
http://www.amazon.com/TYC-20-3071-00...cm_rdp_product
After sanding/steel wooling most the rust off of the horizontal adjuster screw balls, and covering them with white grease, when I went to snap the left headlamp in place it broke the inner adjuster plastic housing to pieces. Sure wasn't happy about this and the Sat parts guy at the dealer didn't have a clue if they sold this adjuster or just the plastic gear housing (diagram, #17. Retainer, Drive Gear?).
Since stuck I had to use plastic weld on the outside of the plastic gear housing w/o getting it on the screw shaft or face where it mounts to the plastic header slot. Then had to wait a couple hours for setting up before installing.
As usual the dia on the plastic ball clips was too small on this aftermarket headlamp so had to change out the clips from the old one to new. And when installing this time I put a block of wood behind the metal towards the engine compartment to support the back of the horizontal adjusting screw which is just even w/the metal when properly adjusted. Also supported the short adjuster towards the outside of the fender with my fingers when snapping the outside of the headlamp in place. Since I had the proper sized clips this time the install went much easier.
I was originally going to ask if anybody knew if the "Retainer, Drive Gear" was the correct plastic gear housing part? But just called the usual parts guy at the dealer and they sell the whole adjuster for $10 while having them in stock.
Just thought I'd pass this along in case anybody else bought this same headlamp assembly and you can read my Amazon review on NOT an easy install on a 96 ZJ. Have no idea how the other guy with a 96 said it was so easy. I will say the headlights look a whole lot better w/brighter light than the old ones.
Headlamp assembly-lamps, 94-96 parts list, p. 8-1145.jpg   Headlamp assembly, med size-broken adjuster housing-pivot, 4-29-2013.jpg   Headlamp assembly-broken adjuster housing-pivot, case whole, Med-size, 4-29-2013.jpg   Headlamp assembly header, adjuster slot, Med-size, 4-29-2013.jpg
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #2 of 22 Old 04-29-2013, 12:08 PM
zander21510
I think its one of those hit or miss things. I got some off of ebay, the sockets are total crap, they don't snap at all. I was only able to get it to snap on one of the balls (because i was able to use the OEM socket...). I also read good reviews on how good it fit.
My solution: some sillicone adhesive. Just strong enough to hold it in place even at highway speed, weak enough where I can pull it out without damage if i need to .
zander21510 is offline
post #3 of 22 Old 04-29-2013, 02:07 PM
xcaliber81
Ouch im about to order some oem style headlights online too for something like 100 $ with shipping. I hope I dont have the same problems
xcaliber81 is offline
post #4 of 22 Old 04-29-2013, 08:42 PM Thread Starter
Uniblurb
Uniblurb's Avatar
It was kind of interesting the socket clips on the new left and right headlights were different color but the headlamps were made by the same manufacturer. Almost like the clips themselves were made by someone else which wouldn't doubt.
Not sure about using silicone adhesive but one of the reviewers said they cut the slots clear down to the base with a hacksaw blade on the socket part, like the OE ones, to get them to fit. Bet this is a trick though since there's only 3 tabs/slots so you can't run a blade clear across.
Believe I'd be looking at the clip sockets closely to see if they're the same diameter. Switch them out if they aren't. Regardless, I'd be supporting the back of the adjuster the best you can before snapping them in place. I was even able to put a 2"x2"x3/4" plywood scrap on the back of the adjuster screw on the metal back between the battery w/o having to remove the battery itself.
I went back and re-sanded the end-balls on the adjuster screws real smooth with fine emery cloth, even put a lighter under the socket to warm the plastic up for a few secs, sprayed with white grease, and snapped them in quickly. Good luck.
post #5 of 22 Old 04-29-2013, 09:57 PM
Pugulis
I ran into almost the exact same problem today. I was in an accident and finally had a chance to replace my header panel, and new passenger side headlight, side marker light and turn signal. The one clip is square and the other two are round. The square one (upper clip) went in fine, but the two lower ones didn't fit at all. But I noticed they did spin. So I used some hot glue and it worked great. Unfortunately when installing the drivers side headlight I broke the square upper clip. So now I have to find one of those.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline
post #6 of 22 Old 04-30-2013, 01:39 AM
kensnelling
The OE part numbers you're looking for are
4762489 Round retainer to horizontal adjuster and pivot stud 2 per side
4762490 Rectangular retainer to vertical adjuster 1 per side
Ken
kensnelling is offline
post #7 of 22 Old 04-30-2013, 03:32 AM
KoreaZJ
1994 ZJ
My 94 adjusters are crap. They were binding and finally stripped the bevel gears. Few years back, cleaned replaced EVERY piece short of the header panel. They're still nearly impossible to move. If I force them, the gears will just strip again.
Anyone had good luck lubing these? I did not, just figured it would collect more dirt.
KoreaZJ is offline
post #8 of 22 Old 04-30-2013, 09:57 AM
zander21510
IIRC I have to "help" the adjusters along. I use pliars and twist the ball as I turn the adjuster gear, because KT binds and strips just like urs. I feel like older and non OEM header panels probably have too much give and allow the adjusters to bind up
post #9 of 22 Old 04-30-2013, 10:26 AM Thread Starter
Uniblurb
Uniblurb's Avatar
When I removed my old headlamps the square plastic clips stayed on the ball of the adjuster screw while coming out of the assembly itself. Figured why not use them over and removed the new square clips from the new headlamps. But when installing the left assembly one of the old square clips broke so used the new square clip I removed. Shouldn't you have an extra from the old headlight assembly or did both the new and old ones break?
Ken
Some good info to know, thanks! I checked with Mopar-wholesale online and the 4762489 round clip is listed as "Retainer Reflector T" for $6.76/each and the rectangular 4762490 is also listed as a "Retainer Reflector T" for $6.83/each. This is w/o shipping and wonder is they would be a lot higher at the dealer since they already seems kind of pricey if replacing all of them?
I'm not sure but thought maybe they changed the adjusters starting in 96? I was kind of surprised when the plastic adjuster housing broke open on mine the gears were still rust-free with just a little bit of hard white grease stuck to the inside of the plastic. But it seems like the shafts/screws were rusted/swollen where it rides against the plastic causing somewhat of a bind. Since it was apart I used the wire wheel on my grinder for taking this rust off the shafts/screws.
On all the other adjusters I just shot some PB down into them and who knows if it helps to lubricated but may stop the rust for a little while the vertical screw turned easier.
post #10 of 22 Old 04-30-2013, 03:39 PM
Pugulis
I was in an accident, so the passenger side one was already broken. I'm probably going to just get a new headlight. Now that I've got one new one, the old one looks funny.
Pugulis is offline
post #11 of 22 Old 05-01-2013, 07:59 AM Thread Starter
Uniblurb
Uniblurb's Avatar
Ahh, understand. Agree with just one headlight replaced it would look a little funny. If you get another new one you may end up with 2 square clips to work with, old and new, while maybe using one of them for the passenger side which broke.
I had de-glazed the front of my headlamp assemblies last year, they really didn't look all that bad, but nothing like new. But then they started leaking water over the winter with condensation inside and needed replaced. Even though I had lots of problems with the new ones they sure look a whole lot better and vast improvement in being able to see at night while driving.
post #12 of 22 Old 05-01-2013, 08:13 AM
xcaliber81
Would getting new adjusters and clips make it easier?
post #13 of 22 Old 05-01-2013, 10:18 AM Thread Starter
Uniblurb
Uniblurb's Avatar
It may but there's no sense in making that investment, around $40 for each headlamp assembly, unless you're going to need them. If you support the back of the adjusters when snapping the assembly in place there's a good chance you won't break them and they shouldn't need adjusted. While changing out/switching the round socket clips from old to new is a pain I wouldn't pay $7/each for them and who knows if they may also have a small socket?
post #14 of 22 Old 05-01-2013, 10:58 AM
xcaliber81
Either way I need the clips mine are broke. What kind of clips are there and how many will I need per headlight? I ordered my new lamps last night cost me 82 $ with shipping. Shipping was 21 $.
post #15 of 22 Old 05-01-2013, 10:49 PM
kensnelling
Your new headlamps will come with clips. If you still need more I listed the part numbers and quantitys in post #6.
Ken
