New guy with a ZJ - JeepForum.com
post #1 of 17 Old 03-25-2013, 02:43 PM Thread Starter
Ahmed10
ZJ
New guy with a ZJ
Just bought a 97 ZJ and did a little bit of work. Its idling pretty rough so im trying to figure it out. I did some research and it could be my PCM connections, plugged cat, etc.. I hope to learn alot.
Ahmed10 is offline
post #2 of 17 Old 03-25-2013, 05:03 PM
ElkhornRanch
Clean your IAC, search for it, there's a great tutorial on it on here.
ElkhornRanch is offline
post #3 of 17 Old 03-25-2013, 09:58 PM
JacoToTheB
Welcome to the forum! I'm fairly new too. My 97 had a rough idle and a new IAC cured it.
'97 ZJ
K&N drop-in & Slow
F150 F>R (The link below because I couldn't figure out how to hyperlink...)
http://www.jeepforum.com/forum/f13/my-jeep-build-infamous-f150-coils-1767489/
JacoToTheB is offline
post #4 of 17 Old 03-25-2013, 10:25 PM
Roskoe
Start a repair fund , keep a little something on the side
"aut viam inveniam aut faciam"
I hate when old people poke me at weddings, point and whisper, "You're next." So I've started doing the same thing to them at funerals
Roskoe is offline
post #5 of 17 Old 03-25-2013, 10:46 PM
dnuccio
IAC valve, clean it or replace it. also not a bad idea to take your throttle body off and clean it as well. mine ran so much smoother after i cleaned the throttle body
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 17 Old 03-26-2013, 12:29 PM Thread Starter
Ahmed10
ZJ
well now it is idling pretty rough and the engine cuts off once and a while. What can i do? if pictures will help, just tell me what part of the jeep you want to look at and i will post it.
Ahmed10 is offline
post #7 of 17 Old 03-26-2013, 12:46 PM
jeepfan2218
jeepfan2218 is offline
post #8 of 17 Old 03-26-2013, 12:51 PM
bananaslug
bananaslug is offline
post #9 of 17 Old 03-28-2013, 01:56 AM Thread Starter
Ahmed10
ZJ
hi guys I got a new IAC but my car still stalls on me, any help will be welcomed.
Ahmed10 is offline
post #10 of 17 Old 03-28-2013, 02:03 AM Thread Starter
Ahmed10
ZJ
new and old one how come they are shaped different.
Ahmed10 is offline
post #11 of 17 Old 03-28-2013, 09:05 AM
dnuccio
The plunger came out of your old one
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 17 Old 03-28-2013, 12:23 PM Thread Starter
Ahmed10
ZJ
any thing to help with the Jeeps stalling problem.
Ahmed10 is offline
post #13 of 17 Old 03-28-2013, 07:37 PM Thread Starter
Ahmed10
ZJ
would changing the catalytic converter help with the stalling problem.
Ahmed10 is offline
post #14 of 17 Old 03-28-2013, 11:15 PM
jm8881
Does it run rough all the time? Does it get any better or worse when it warms all the way up? Is your check engine light on? How many miles does it have? When was the last time simple maintenance was done on it such as plugs wires cap and rotor? What about the fuel filter?
I wouldn't throw any more parts or money at it until we get a little more information. It could be something as small as needing a tune up. Or even one spark plug wire arcing.
jm8881 is offline
post #15 of 17 Old 03-29-2013, 12:03 AM
angry_trucker
1998 FSJ Cherokee
I had the same problem...mine turned out to be the sparkplug wires...
I put in new 8mm NGK wires and no more cutting out..
98 Jeep Grand Cherokee Laredo 4.0
Selec-Trac
Everything stock.
angry_trucker is offline
