-   -   New guy with a ZJ (http://www.jeepforum.com/forum/f13/new-guy-zj-1498917/)
Ahmed10 03-25-2013 02:43 PM
New guy with a ZJ
Just bought a 97 ZJ and did a little bit of work. Its idling pretty rough so im trying to figure it out. I did some research and it could be my PCM connections, plugged cat, etc.. I hope to learn alot.
ElkhornRanch 03-25-2013 05:03 PM
Clean your IAC, search for it, there's a great tutorial on it on here.
JacoToTheB 03-25-2013 09:58 PM
Welcome to the forum! I'm fairly new too. My 97 had a rough idle and a new IAC cured it.
Roskoe 03-25-2013 10:25 PM
Start a repair fund , keep a little something on the side :welcome:
dnuccio 03-25-2013 10:46 PM
IAC valve, clean it or replace it. also not a bad idea to take your throttle body off and clean it as well. mine ran so much smoother after i cleaned the throttle body
Ahmed10 03-26-2013 12:29 PM
well now it is idling pretty rough and the engine cuts off once and a while. What can i do? if pictures will help, just tell me what part of the jeep you want to look at and i will post it.
jeepfan2218 03-26-2013 12:46 PM
http://www.jeepforum.com/forum/f9/cl...mmies-1114849/
Try this it helped me out a ton!
bananaslug 03-26-2013 12:51 PM
http://www.jeepforum.com/forum/f13/1...talls-1407423/
good luck!
Ahmed10 03-28-2013 01:56 AM
2 Attachment(s)
hi guys I got a new IAC but my car still stalls on me, any help will be welcomed.
Ahmed10 03-28-2013 02:03 AM
2 Attachment(s)
new and old one how come they are shaped different.
dnuccio 03-28-2013 09:05 AM
The plunger came out of your old one
Ahmed10 03-28-2013 12:23 PM
any thing to help with the Jeeps stalling problem.
Ahmed10 03-28-2013 07:37 PM
would changing the catalytic converter help with the stalling problem.
jm8881 03-28-2013 11:15 PM
Does it run rough all the time? Does it get any better or worse when it warms all the way up? Is your check engine light on? How many miles does it have? When was the last time simple maintenance was done on it such as plugs wires cap and rotor? What about the fuel filter?
I wouldn't throw any more parts or money at it until we get a little more information. It could be something as small as needing a tune up. Or even one spark plug wire arcing.
angry_trucker 03-29-2013 12:03 AM
I had the same problem...mine turned out to be the sparkplug wires...
I put in new 8mm NGK wires and no more cutting out..
The time now is 07:23 PM.
