New GC for the wife...questions - JeepForum.com
post #1 of 2 Old 07-03-2003, 12:56 PM Thread Starter
twmattox
Just got a Grand for the wife and I have questions. I am very familiar with older Grand Wagoneers and CJ's, but am all lost with this thing. Please help.
4.0 L I-6 engine, unknown automatic tranny, selectrac t-case, unknown axle ratios
The problem is:
When starting you can turn the key for anywhere between 1-20 seconds and the engine rotates but will not fire. Stop for a second, turn the key again, and it fires right up. Any ideas?
I have had a similar problem in an older CJ. Ended up that the fuel pump was losing prime. However, it would always start after about 15 seconds on the initial turn of the key. This GC will not, no matter how long you leave the key turned. And, even if you only crank if for a second or two then crank again, it will fire right up.
Help...
twmattox is offline
post #2 of 2 Old 07-03-2003, 02:21 PM
ILoveto4x4inNC
I had a similar problem with my 98ZJ. I replaced the fuel level sending unit and it hasn't acted up since.
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline
So my wife wants a wj xwildman138x ZJ Grand Cherokee Forum 58 08-29-2009 07:11 AM
looking for wk for wife what to look out for nomesio WK Grand Cherokee & XK Commander Forum 1 05-25-2009 01:02 PM
looking to buy a used WK for the wife.. what should i look out for? Greggk300C WK Grand Cherokee & XK Commander Forum 4 08-29-2008 12:13 PM
The wife just doesn't understand... FPKites ZJ Grand Cherokee Forum 18 11-23-2005 01:47 PM
HELP!! What to get the wife for her WJ??? bdhaley ZJ Grand Cherokee Forum 21 07-14-2004 10:20 AM
