New Exhaust=Code 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > New Exhaust=Code 21
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 10-01-2014, 10:51 AM   #1
billd
New Exhaust=Code 21
Hi! I have a 95 Gr. Cherokee with a 5.2
I just put a new cat.converter and a muffler on and now after 5 minutes of
driving the Check engine light comes on. It really ran crappy immediately after doing the install but has since smoothed out somewhat.
The code I pulled is 21 for the oxygen sensor.
Don't quite get how components downstream can affect the sensor?
How can I fix this? Thoughts?
Will it hurt it to drive it this way?
Thanx!!
billd is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 11:04 AM   #2
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You will burn more gas.
You did the install or a shop?
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 11:06 AM   #3
billd
I did the work.
Unread 10-01-2014, 11:10 AM   #4
HighLonesome
Code 21 is an electrical problem. Last time I saw that code it was a broken wire.
Did you reset the computer?
Unread 10-01-2014, 11:17 AM   #5
billd
Yes, being a 95 I had to undo the neg. battery cable. That worked and the code is gone. I haven't driven it yet to see if the code will return, however. Getting ready to do that now. The old cat. conv. was toast and all broken down inside. I had a 13" Flowmaster muffler on it and replaced that with a 18" OEM sized Walker muffler. It really ran like crap during the test drive after doing the work but has smoothed out considerably.
Gonna go test drive it again now.
Unread 10-01-2014, 11:22 AM   #6
HighLonesome
Mine acted like that when a wire was broken. Code always came back after a couple minutes. Hopefully yours will stay gone.
If it does come back, I guess I would check the wiring first. After that the obvious...replace the sensor. There is a heater inside the 02 sensor. If the heater opens electrically, that will cause the code.
Unread 10-01-2014, 11:35 AM   #7
billd
Yeah, the code came back after about 2 miles. It's weird because if I turn the engine off and restart the code is gone until I drive a few miles. Don't get it as before the new components ...no light. And I was no where near the O2 sensor. I looked at it briefly and there was nothing obvious with the wires from the sensor. I'm wondering if she doesn't like the new muffler. Maybe a bit more back pressure could be causing this. She has 180,000 on the clock and has never given me this kind of grief. I guess I'll try replacing the sensor. It's gonna be a bear, though, as it's probably been in there since 95.
Unread 10-02-2014, 03:28 AM   #8
ZeeJay1997
Originally Posted by billd View Post
\ it's probably been in there since 95.
more the reason to change it. get an ntk brand sensor. others may cause problems.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 10-02-2014, 07:14 PM   #9
billd
Yeah....I know. All I gotta do now is figure a way to get it out. I've had round 1 with it already.
Unread 10-02-2014, 07:21 PM   #10
ZeeJay1997
i had good luck with remove it while the pipe is hot.
