New Engine swap question - JeepForum.com
post #1 of 5 Old 05-15-2005, 11:11 PM Thread Starter
OffroadZJ
OffroadZJ's Avatar
For those who have swapped their engines out AFTER lifting their jeep, how in the hell did you get the engine out/in? I cant find any hoists high enough to be able to get the engine out, and it looks like it may be too involved to remove it out the bottom... so how did you do it?
Any pics would be great.
Thanks
Kenny
1994 5.9L ZJ. RK 7" long arm, 35" Super Swamper Trxus M/T mounted on Pro Comp extreme alloys. Ford 8.8 w/ 4.10 and powertrax locker, hp30 w/ 4.10 (open for now), Warn Tabor 9000. Soon to come: Hanson Enterprise front winch bumper, hand made rear bumper with carrier, hand made skid plates. 242 case is sitting in my garage waiting for a warm day to transplant.
OffroadZJ is offline
post #2 of 5 Old 05-16-2005, 05:51 AM
brandoncrone
Use a come-a-long or a chain fall/ I'm sure you have a nice tree branch around someplace!
Dodge/Chrysler/Jeep Technician 14 Years
ASE Master Certified
L1 Advanced Engine Performance
brandoncrone is offline
post #3 of 5 Old 05-16-2005, 06:13 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Kenny,
I told you that you shouldn't bought that 7 inch RK lift. See, this is the kind of problems you have afterwards...
maybe you could park the jeep at a loading dock and use the normal lift from inside the dock with the jeep parked below?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 5 Old 05-16-2005, 09:54 AM
AvyZJDriver
Try either letting all the air out of your tires, or hell take your tires and rims off and set the thing on some wood blocks? that will lower you alot then put the engine hoist on an impromtu roller stand you can weld up and bolt to the bottom of the hoist. id trust that over some tree, which i thought was a good idea myself but I like this better =D
Brett
98 ZJ limited 5.2 L
RE long arm kit slightly modified King 2.5 shocks
Currie Ford 9" front end Ford 9" rear end 4.56 gears
Atlas II 4.3:1, 35s, tube frame and a lot of cutting
AvyZJDriver is offline
post #5 of 5 Old 05-16-2005, 09:56 AM
AvyZJDriver
Try either letting all the air out of your tires, or hell take your tires and rims off and set the thing on some wood blocks? that will lower you alot then put the engine hoist on an impromtu roller stand you can weld up and bolt to the bottom of the hoist. id trust that over some tree, which i thought was a good idea myself but I like this better =D Another thing you can do is spend about 30 bucks on some of those old spring compressors you used to see in crappy lowered cars the ones with the hook and bolt that just compressed the spring to itself in car and you swore was gonna take someones head off if they broke.
Brett
98 ZJ limited 5.2 L
4.0 engine swap question? TravisP32 ZJ Grand Cherokee Forum 4 09-11-2009 10:32 PM
Question About a 4.0 engine swap tdd8ball ZJ Grand Cherokee Forum 4 09-03-2009 01:23 PM
Engine swap question Fiend101 ZJ Grand Cherokee Forum 2 03-15-2009 10:06 PM
engine swap question sevierville01 ZJ Grand Cherokee Forum 1 01-31-2009 04:57 PM
engine swap question vtlaxplaya16 ZJ Grand Cherokee Forum 2 10-02-2006 04:52 PM
