New CV Joint do wheels need to be aligned?
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
Drivers side CV joint is being replaced. Will I need to have the wheels aligned? The vehicle is a 2000 GC.
#2 | |
no..but you might wanna do both at the same time
-Jeb 99 WJ 4.7V8 selc-trac swap 285s re-tread IRO 6.5 Long Arms Aussie Locked Rear in the works... lots deployments are great for jeep budgets Go Doorless! Things i need.. good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share Quote:
#3 |
Thanks. I was going to have him check the passenger side. Since the drivers axel has to come off would you just replace with a refurbished axel or just replace the cs joint and a new boot? The labor would probably be cheaper to just replace with a refurbished drive axel.
#4 |
replace the outer axle.. cheaper with labor.
and id reccomend changing both sides if possible at same time. could try replacing yourself if you have some tools and some wrenching knowledge u could save some money
[B]Kyle[/B] 99 XJ Classic, 4.0, AW4, 8.25 Rear 4.5" (~6'') RC lift w/ full leafs, RE 1.25" Shackles, Bilstein 5125's, IRO Custom HI-Clearance LA's,JKS quicker discos, C4x4 Front Hooks, TW's SYE/CV DS, FLO-PRO cat-back, and some 32'' x 11.50" Maxxis Bighorns |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
