new cat o2 sensor - JeepForum.com
post #1 of 18 Old 12-02-2009, 08:09 PM Thread Starter
kinnelonconst
new cat o2 sensor
I just recieved my flowmaster 44 and my highflow cat, what do i do with the o2 sensor i am not sure how to put it in the new
96 Grand Cherokee Laredo 5.2 v8, K&N cold air intake, magnaflow highflow cat, no muffler, 31" Mickey Thompson Baja MTZ, and other doodads
kinnelonconst is offline
post #2 of 18 Old 12-02-2009, 08:10 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Where is the stock O2 sensor? in the Cat?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #3 of 18 Old 12-02-2009, 09:13 PM Thread Starter
kinnelonconst
yeah right in the end of the cat and i have the magnaflow cat but dont know what to do with the sensor
post #4 of 18 Old 12-02-2009, 11:36 PM
teenwolf1393
wow dude. just wow. put the o2 sensor in the new cat. there should be a bung for it on the exit side of the cat if not your gonna have to get one put on. a muffler shop will do it for relatively cheap
teenwolf1393 is offline
post #5 of 18 Old 12-03-2009, 01:01 AM
ZJ5point2GCL
sounds like you got the wrong cat, pre OBD II had no bung for it, but OBD II's have a bung as part of the cat. was just looking at the 2 today
ZJ5point2GCL is offline
post #6 of 18 Old 12-03-2009, 01:01 PM Thread Starter
kinnelonconst
i just got a universal cat, not a specific cat, therefore there is no hole for the sensor
post #7 of 18 Old 12-03-2009, 01:16 PM
ZJ5point2GCL
Yeah, there are two universal cats from magnaflow / carsound one with an o2 sensor bung, one without
post #8 of 18 Old 12-03-2009, 06:34 PM Thread Starter
kinnelonconst
where can i buy the part that i need to weld into the exhaust pipe? whats it look like
post #9 of 18 Old 12-04-2009, 12:45 AM
ZJ5point2GCL
where did you buy the cat from?
post #10 of 18 Old 12-04-2009, 12:49 AM
ZJJay
ZJJay's Avatar
I'll bet any good muffler shop could drill a hole and weld the bung in. I doubt if it's that big a deal. But I hope you don't live in California. We have to have special cats which cost maybe $100 more than the other 49 states. Lucky us!
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #11 of 18 Old 12-04-2009, 08:40 PM
teenwolf1393
the bung basically looks like a bolt welded onto the muffler/piping any muffler shop should be able to do it quick and inexpensive.
post #12 of 18 Old 12-04-2009, 10:25 PM
stageninja
That Rigger Guy
stageninja's Avatar
Or maybe a nut
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #13 of 18 Old 12-04-2009, 10:44 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
you may want to buy a section of pipe that has the bung already in it. Idk what its called tho
post #14 of 18 Old 12-05-2009, 06:44 PM Thread Starter
kinnelonconst
i ordered the bung from one of my local autoparts store, comming in monday... will weld it onto the new connector pipe between cat and muffler, and should be all hooked up monday night
post #15 of 18 Old 12-05-2009, 06:51 PM
ZJJay
ZJJay's Avatar
This sounds really obvious, but I'll mention it anyway. Make sure that the location where the muffler shop installs the bung is within reach of the O2 sensor wiring. You don't want a strain on the wiring connector. You also want the bung at an angle that would make removing the sensor easy with a box or open end wrench (if you don't have the special O2 sensor socket - a deep socket with a slot to allow the wires to hang out).
ZJJay is offline
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 11:22 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 01:41 PM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 10:04 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 04:52 PM
