New brakes - JeepForum.com
post #1 of 11 Old 05-09-2013, 10:01 PM Thread Starter
garretthadsell
New brakes
Im in need of replacing my brakes and rotors. I'm looking at the drilled and slotted rotors any one have then on there jeep? would they be good I only do the occasional off roading. Or should I just get solid ones?
garretthadsell is offline
post #2 of 11 Old 05-09-2013, 10:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
PM Kolak, he has made a bunch of people on here very happy with some drilled and slotted rotors he has.
kg6mov is offline
post #3 of 11 Old 05-09-2013, 10:29 PM
riot1987
Ive heard this discussion go both ways. I personally dont like drilled rotors because I like to wheel and drilled/slotted rotors just pack with snow and mud. If you want some better brakes look into EBC stuff. They are pricey but heard they make a difference. These jeeps just dont have a very good (competent) braking system unfortunately w/o swapping to bigger, better components.
Build thread^^
riot1987 is offline
post #4 of 11 Old 05-09-2013, 10:33 PM
kg6mov
Hears the voices
kg6mov's Avatar
I run bosch rotors and performance friction pads on the front on mine and they're great. Eventually wj calipers are the way to go.
kg6mov is offline
post #5 of 11 Old 05-10-2013, 12:44 AM
Kolak
Vendor
Kolak's Avatar
I've recommend Stillen cross-drilled rotors for Jeeps for over 15 years and you will be very impressed with them. They do all their machining and drilling in their southern California and use on the finest quality one-piece cast rotors. Send me a PM here on the forum and I'll get back to you with information and pricing. I have them on special now too
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #6 of 11 Old 05-10-2013, 03:52 AM
gearheadnick
I'm running drilled and slotted rotors and ceramic pads on my Jeep, and I have no complaints.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #7 of 11 Old 05-10-2013, 05:12 AM
Technohead
Drilled/slotted rotors benefit repeated high-speed braking. You are driving a Jeep not a race car. The most cost effective upgrade would be quality brake pads. I recommend Hawk HPS.
-Eric
Technohead is offline
post #8 of 11 Old 05-10-2013, 07:54 AM
Jeeples
Jeeples's Avatar
This guy knows what's up
Performance Friction pads are what I run on my SRT-4 and my wife's WJ and they are excellent, low dusting hard biting pads.
I have Bosch solid rotors on my SRT, and they are very high quality pieces, but a little spendy.
I just recently installed a set of Brakeperformance.com slotted only rotors on the front of my wife's WJ and have been very impressed with them so far. WJ's are known for warping rotors up front (with either brake caliper setup) and the last set of Raybestos drilled and slotted rotors went 35k before they were too thin to reuse. That sold me on the importance of keeping the rotors cooler for longer service life.
I should note that my wife's WJ was our only offroad vehicle and made many trips up and down Parley's Canyon here in Utah loaded with camping gear and I never once overheated the brakes or experienced brake fade.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #9 of 11 Old 05-10-2013, 12:16 PM
1ATony
Vendor
1ATony's Avatar
We carry some great brake pad and rotor kits for your Jeep Grand Cherokee. Here's a link to them on our site Jeep Grand Cherokee Brake Pads and Rotors
I used to run slotted rotors on my WJ, what I didn't like about them is that they would make noise when coming to a stop, have since switch back to the ones we carry on both of my Jeeps. They're made really well.
SHOP HERE FOR AWESOME
1ATony is offline
post #10 of 11 Old 05-10-2013, 01:12 PM
tucsonzj
I got mine through kolak. Stillen cross drilled rotors with performance friction carbon metallic front pads and metal matrix rear pads. Stop great, no more shake (my old ones were warped). Test of time will only tell, but so far I'm extremely happy with them.
If you go to my build thread below, you can see a pics of the stillens I got when I installed them.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #11 of 11 Old 05-10-2013, 03:45 PM
zjosh93
X3 on the performance friction pads. I've had them on all my vehicles for the past ten years. No complaints, very good wear, very good braking.
zjosh93 is offline
