New beater ZJ, some??? - Page 4 - JeepForum.com
post #46 of 70 Old 12-17-2013, 07:33 AM Thread Starter
Thomahawk
^^^Thx man, Those Are Good pointers about the ABS system.
No its a 95, with a 98 niner interior and hood'n bumber, thats why i got interested and it was almost given to me, it was planned to be my Winter beater, but them i bought the 04HO, and now its just my project, its kinda cool, it will be a fun Jeep.
Buildthread
Thomahawk is offline
post #47 of 70 Old 12-17-2013, 09:38 AM
Purcell69
If the Magnum engine uses the same beer keg looking intake manifold as the Dodge pickups use, you may have a leaking plenum gasket at the base of the intake manifold. It is a common failure, since the plenum is steel and the manifold is aluminum. The dissimilar metals cause the gasket to start leaking over time, which may account for your failed emissions on the inspection. If you can see wet oily substance in the bottom of the intake manifold, you have a leak. Hopefully this is not the problem you are having.
-Joe
Purcell69 is offline
post #48 of 70 Old 12-17-2013, 12:06 PM
PolkaPower
-Joe
They do, it's the same motor for the 5.2 and 5.9. All are cursed with the phantom of the plenum gasket.
PolkaPower is online now
post #49 of 70 Old 12-17-2013, 02:13 PM Thread Starter
Thomahawk
Hmmm i will check That out,
Got parts from Kolak today, 8 days from AZ USA > Norway, pretty impressive to me, guess paying That USPS EMS shipping was worth every penny.
Parts arrieved,
Rear hatch supports for 2 ZJ's
Brake shoe assembly kit
Front Lower Control arms
Next will be to find some time to Get at it.
Buildthread
post #50 of 70 Old 12-17-2013, 02:22 PM
PolkaPower
You don't even have to guess if the plenum is leaking. It leaks on 100% of ZJ's from the factory eventually. Mine had started leaking before I bought it at 127k miles. It was a mistake they made putting a steel pan on a aluminum block. Those two metals heat and cool at different temps so it squeezes the gasket out.
Here is the solution, or you could just weld it shut. http://www.hughesengines.com/Index/p...p?partid=27091
post #51 of 70 Old 12-17-2013, 03:04 PM
newfieZJ
Stock plenum is never tight . My 5.9's are hitting 140-150k and I noticed a oil consumption increase last oil change but always went through a little . Definitely something I need to get at .
My Orvis , it only has 58k on it's engine from a 01 Ram . I did the plenum on it 4ish years ago with a fel-pro gasket and some anaerobic gasket maker lightly spread on both sides of the gasket . Everyone swears by the alum. plate , but , that works too The oil level is the same after 3-4k on that jeep .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #52 of 70 Old 01-04-2014, 11:20 AM Thread Starter
Thomahawk
Got around to do some Work today,
Disassemblied and cleaned out rear brakes,
ABS sensors,
its was ****ty in there, mounted new parking brake shoe kit.
Retorqued pinion nut, really tight now, but still not 115gr/1m arm to spin it, afraid to tighten it more so put it back together again.
New rear hatch supports.
Reassemblied brakes and wheels and Adjusted the handbrake, thats it for today.
Buildthread
post #53 of 70 Old 01-05-2014, 12:04 PM Thread Starter
Thomahawk
Update on todays progress,
Exhaust clamps before and after cat,
Sparks plugs, old was Way over gapped, hopefully this will Get me threw on emmision.
Left lower control arm, bushing at axle side was all toast, and sleeve stuck to bolt.
Took me hours to cut and split the sleeve, but the ones That aint giving in, win
Buildthread
post #54 of 70 Old 01-05-2014, 12:50 PM
PolkaPower
Your drive shaft looks F'ed. Is it?
post #55 of 70 Old 01-05-2014, 12:58 PM Thread Starter
Thomahawk
Idk, i think its ok, what you see That indicates That?
Buildthread
post #56 of 70 Old 01-05-2014, 01:15 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by WJ4x4LIFE View Post
Always a great start to do the maintenance first and then go from there. Oh, by the way that broken front driver's side turn signal light assembly lens is killing me! hahaha. Keep it up!
lol
that splice on the alt power wire is killing me
HighLonesome is offline
post #57 of 70 Old 01-05-2014, 01:17 PM
PolkaPower
I guess it's just the angle at which the pic is taken. Looks like it's bent.
post #58 of 70 Old 01-05-2014, 01:21 PM
HighLonesome
That driveshaft does look wrong.
Plugs look good! no engine problems likely
post #59 of 70 Old 01-05-2014, 01:24 PM Thread Starter
Thomahawk
Originally Posted by HighLonesome
lol that splice on the alt power wire is killing me
Me too, as an electrician, i cant handle to see things like That, its on my list to Fix, PO did many strange thinghy's, like the conection made at the IAC/TPS wireing, shorting to the block.
Yeah, its the angle, also its jacked up in the front, had no problem with it so far, boot look ok.
Buildthread
post #60 of 70 Old 01-05-2014, 01:28 PM Thread Starter
Thomahawk
That driveshaft does look wrong. Plugs look good! no engine problems likely
Engine runs very Nice now after everything i did.
Havent got around to drive it much as i dont have the licence plates yet, and no other ZJ to take from lol
Didnt pass inspection, due to to high CO2 if i remember correct.
Fixed leak before and after cat and changed plugs, if That aint curring it, i will investigate intake leak as recomended before.
Buildthread
