New beater ZJ, some??? - JeepForum.com
post #1 of 70 Old 11-07-2013, 12:03 PM Thread Starter
Thomahawk
2006 XK Commander
Maybe going for a DD/Beater swap, might get this one for cheap, lol looks like a good project.
but dont know to much about Those 5.2's
http://m.finn.no/car/used/ad.html?fi...&engine_fuel=1
It would be Nice to upgrade to a 95 limited with V8 from my 94 4,0 laredo,,,
It has new brakes all around, new bushings and balljoints all over the front end,
98 5.9 interior stereo and hood,
Good Winter wheels,,,
Licence plates been off, need new periodic control to Get them back on, seller Claims rear diff seal is only thing need to be fixed from the control list.
It also have some idle issues. Seller tried new IAC, but maybe not cleaned Throttle body, or TPS/MAP?
It also have a bad battery, can this maybe be the one and only issue causing electronic to Go haywire and cause idle issues?
Anyone???
Going to see it and hopefully buy it in this weekend.
T
Buildthread
Thomahawk is offline
post #2 of 70 Old 11-07-2013, 12:48 PM
BoostinBubba
Bad battery can definitely cause you problems, these vehicles are sensitive to that.
BoostinBubba is offline
post #3 of 70 Old 11-09-2013, 12:19 PM Thread Starter
Thomahawk
2006 XK Commander
Bought it today Got it tested real Good with 320km back home from the mountain,
Jeep did ok and ran all the Way, no big issues, suspension and Steering feels tight and nice,
Steering wheel is off to the left,
Rpm drop, prob bad homebrew electro conection TPS,
Sticking front right brake caliper, seemed to fixed itself after 200km,,,?
ABS light on,
No kick down,
Low oil pressure?
Will have a better look at everything tomorow, cool new project
Buildthread
post #4 of 70 Old 11-09-2013, 12:24 PM
WJ4x4LIFE
I like it!
WJ4x4LIFE is offline
post #5 of 70 Old 11-09-2013, 01:26 PM
riot1987
Those wheels look sharp
Build thread^^
riot1987 is offline
post #6 of 70 Old 11-09-2013, 02:07 PM Thread Starter
Thomahawk
2006 XK Commander
What fluid goes into these ZJ 95 5.2's?
What trans do i got? ATF?
Axles? Fluid 75w-140?
Transfer 249, ATF?
What spark plugs?
Planing a full Tune up, pls advice recomend fluids etc,,,
Buildthread
post #7 of 70 Old 11-09-2013, 02:09 PM
riot1987
I wanna say your trans is a 46rh..? I believe 93-95 5.2's had the bigger, hydraulic transmission, I know 95 they changed a lot of stuff. Look in the FAQ's section. lots of stuff there
Build thread^^
riot1987 is offline
post #8 of 70 Old 11-09-2013, 02:16 PM Thread Starter
Thomahawk
2006 XK Commander
^^^46RH, is correct i believe,
Dana 44A rear
Dana 30 front
NP-249 transfer
Buildthread
post #9 of 70 Old 11-09-2013, 02:42 PM
Pierre_r
1989 XJ Cherokee
ATF +4 in the trans (even says so on the dipstick)
Axles, 75-90 or 75-140 + LS additive for the rear.
Transfer, ATF i use the same as in my trans.
(My trans has been rebuilt and works with dexIII now)
Pierre_r is online now
post #10 of 70 Old 11-09-2013, 02:52 PM Thread Starter
Thomahawk
2006 XK Commander
Cool but what engine oil does it prefer,
And what spark plugs?
Thx
Buildthread
post #11 of 70 Old 11-09-2013, 03:02 PM
Pierre_r
1989 XJ Cherokee
I use castrol 15w-40 in mine and a wix 51085 oilfilter.
Last time i bought sparkplugs for it i got ac delco plugs with this number: DEL41629
Now i have kolaks ignitionupgrade on it so i dont run stock anymore.
post #12 of 70 Old 11-09-2013, 03:06 PM Thread Starter
Thomahawk
2006 XK Commander
How about any noticeble differences with the Kolak upgrade?
Any info/expirience about upgrading to 3" exhaust?
T
Buildthread
post #13 of 70 Old 11-09-2013, 03:16 PM
Pierre_r
1989 XJ Cherokee
The only thing i have noticed is that the idle is a little smoother + it looks good in the enginebay with red wires and msd coil.
I have a set of doug thorley headers that i am going to put on it sometime in the future and already have a 3"cat muffler and pipe from IRO.
Wich btw was a complete pain in the *** too install with the jeep at stock height because of their pipe being a one piece.
post #14 of 70 Old 11-10-2013, 01:53 PM Thread Starter
Thomahawk
2006 XK Commander
Cleaned out TB today,
Refixed homebrew wireing splice TPS,
Vacumed, Cleaned inside and outside,
Toped off engine oil,
Now it runs strong and smooth, very responsive on the Throttle, sure Made a huge difference
Also oil pressure Are back to normal,
Lots of more Work need to be done,
Buildthread
post #15 of 70 Old 11-10-2013, 06:13 PM
WJ4x4LIFE
Always a great start to do the maintenance first and then go from there. Oh, by the way that broken front driver's side turn signal light assembly lens is killing me! hahaha. Keep it up!
