New axle or rebuild? - JeepForum.com
post #1 of 16 Old 12-19-2012, 09:05 AM Thread Starter
funkness
So as i am slowly rebuilding the 98 zj 5.9 (mind you there are many things wrong with it) but i am waiting for my exhaust to come in i am looking on working on the front axle when i bought the jeep i noticed that both the axle shafts were gone in the front so finally yesterday i open the pumpkin to see whats going on inside for them to take both the shafts out and geuss what i find.... Nothing completely empty.. sigh should i rebuild the whole thing or just find a whole used axle?
Thanks
Mike
funkness is offline
post #2 of 16 Old 12-19-2012, 09:21 AM
PolkaPower
Thanks
Mike
lol so there is no ring or gears in there? Wow! This would be a great time to put in a high pinion 30 since you have to get gears anyways. Most the the HP 30's will come with 3.55 gears and you need 3.73. If you are going to lift it to 32's or 33's then you will want steeper gears but the rear will cost quite a bit.
If you are just going to keep it the way it is or maybe get 31's as the largest tire then stick with the 3.73's.
How long have you been driving it like this? The reason I ask is the PO must have grenaded the front somehow. I wonder if your VC in the transfercase is still functioning well. I suppose you will know when you get the front taken care of.
PolkaPower is online now
post #3 of 16 Old 12-19-2012, 09:26 AM Thread Starter
funkness
onlything in there is the gear attached to the yoke...(cracked off teeth lol) i assume the guy who had it before shotguned the front axle and just said **** it and gutted it. i would like to take this opp to upgrade but unsure of what to do lol would like to keep the price under 1200 lol
funkness is offline
post #4 of 16 Old 12-19-2012, 09:29 AM
ajmorell
ajmorell's Avatar
I guess it depends. You could rebuild that axle and know everything is going to be in perfect working order, or you could get a junkyard axle and you might end up having to replace the shafts, bearings, ball joints, etc. If you plan to hang on to the jeep a while the first option seems like the better one even though it's also the more expensive option.
ajmorell is offline
post #5 of 16 Old 12-19-2012, 09:34 AM Thread Starter
funkness
i am going to be honest i have worked on axles once and that was it if anyone has any info on good quality parts// what they would do if they found this issue that would be great
funkness is offline
post #6 of 16 Old 12-19-2012, 09:38 AM
PolkaPower
I have read over and over that setting the pinion bearing pre load when setting up a diff is a skill learned through proper education and isn't something one of us shady tree mechanics should attempt. I would use dana/spicer stuff in it. Maybe you could put a limited slip in the front. That would be useful. Texas ZJ had one with his 249 and no issues I believe.
Here is an informative article. http://www.pirate4x4.com/tech/billavista/Gear_Setup/
post #7 of 16 Old 12-19-2012, 09:47 AM Thread Starter
funkness
Ok this is going to be made fun of but what do i all have to order because i know theres alot of parts and i just want to order them all an get them on their way lol
funkness is offline
post #8 of 16 Old 12-19-2012, 09:49 AM Thread Starter
funkness
http://eastcoastgearsupply.com/i-129...r-3-73-up.html if i order this with the "loaded" option does the loaded mean it comes with gears?
funkness is offline
post #9 of 16 Old 12-19-2012, 09:50 AM
PolkaPower
I think you will need a Dana 30 gear set and overhaul kit. I do not know what else.
post #10 of 16 Old 12-19-2012, 09:51 AM
PolkaPower
No it's just the carrier.
You are going to need all this stuff if your diff is empty
post #11 of 16 Old 12-19-2012, 09:52 AM Thread Starter
funkness
what does the "loaded" option mean
funkness is offline
post #12 of 16 Old 12-19-2012, 09:56 AM
PolkaPower
Loaded with gears I assume. Don't go pend money on sub par parts though. You will only have to do it again later.
post #13 of 16 Old 12-19-2012, 10:48 AM
Technohead
Find a whole used axle and then rebuild it. Id recommend starting with a high pinion from a 96-00 XJ.
-Eric
Technohead is offline
post #14 of 16 Old 12-19-2012, 11:01 AM
SCRMBLD
^What he said. You might get lucky enough to find one with 3.73 gears, assuming that's what you need.
If you keep what you've got and buy the axles, u-joints, carrier, gears and all other needed parts separately; you'll have alot of $$$ into a Low Pinion D30 axle.
Find a High Pinion D30 with the Spicer 5-760x u-joints and rebuild it. If you're unfamiliar with setting gears, rebuild the rest of the axle yourself (easy part), and have a reputable shop rebuild and/or re-gear the carrier.
ΜΟΛΩΝ ΛΑΒΕ
SCRMBLD is offline
post #15 of 16 Old 12-19-2012, 11:02 AM
sandman
Its going to be much cheaper to just roll the dice with a JY axle unless you know how to set up gears.
1993 Jeep ZJ. 4.0
sandman is offline
