neutral safety switch - JeepForum.com
post #1 of 4 Old 04-02-2006, 12:19 AM Thread Starter
joeyschribar
hey there!
on a 94 grand cheroke 5.2 v8, with a 46rh transmission, the vehicle will only sometimes not start in park, other times it will..
it, so far, has always started in neutral..
so i removed the NSS, and clean it, and i still have the same problem, so i changed the fluid in the transmission and still it only works every now and again, is it possible that it could be wiring at all??,
is there a way to check for continuity between the 3 posts on the nss or the connector at all using an ohmeter???
joeyschribar is offline
post #2 of 4 Old 04-02-2006, 09:57 AM
madcabbie
madcabbie's Avatar
Its possible it could just be the switch is bad..if you havent replaced it
99 WJ
4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS|
Everytime Someone calls a Jeep, an SUV, GOD Kills a kitten.
madcabbie is offline
post #3 of 4 Old 04-02-2006, 01:26 PM Thread Starter
joeyschribar
yeah im going to replace the switch today and see if thats the problem, i will report back
post #4 of 4 Old 04-02-2006, 07:19 PM Thread Starter
joeyschribar
ok, i bought a new nss, and as i removed the 3 pin electrical connector, one wire on it pulled through..., right at the end of the connector so there is no way of connecting it back together!~!!
i now know that this was why it would not always start in park, because that wire was really loose and ready to break off.
anyways, ill have to go get a new connector for the nss and then my problem will be solved!
where is the neutral safety switch fordhearter ZJ Grand Cherokee Forum 8 01-19-2010 03:51 PM
neutral safety switch - need new one CorneliusRox ZJ Grand Cherokee Forum 11 12-05-2009 04:13 PM
Neutral Safety Switch canadianb ZJ Grand Cherokee Forum 7 09-03-2008 08:13 PM
Neutral Safety Switch UltimatE ZJ Grand Cherokee Forum 9 12-15-2007 10:42 PM
WJ: neutral safety switch / NSS bad mikejeepers ZJ Grand Cherokee Forum 0 11-28-2006 09:51 AM
