Neutral Safety Switch - JeepForum.com
post #1 of 4 Old 05-26-2011, 08:36 AM Thread Starter
redman4ever
I have a 97 zj 5.2l and have taken it to the transmission shop 3 times to fix a leak that is apparently coming from the neutral safety switch. It starts out fine, gradually it starts being harder to hit the right spot in the gear shift to crank it, then finally it won't crank and is leaking fluid. Anyone know what I could do here?
redman4ever is offline
post #2 of 4 Old 05-26-2011, 11:39 AM
Candymancan
replace the sensor... mine was leaking like half a quart every 2 days beofre i replaced it
Candymancan is offline
post #3 of 4 Old 05-26-2011, 11:49 AM Thread Starter
redman4ever
lol Started having all these problems when they replaced it but I've about decided to just replace it myself. Do you use tread sealer when you go back on or RTV or something?
post #4 of 4 Old 05-26-2011, 01:56 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
green loctite if anything. threads are tapered and should be self sealing.
ratmonkey is offline
ZJ have a neutral safety switch? 3xX ZJ Grand Cherokee Forum 4 03-18-2012 10:34 AM
where is the neutral safety switch fordhearter ZJ Grand Cherokee Forum 8 01-19-2010 03:51 PM
Neutral Safety Switch ry1820 ZJ Grand Cherokee Forum 18 06-04-2008 08:25 AM
Neutral Safety Switch UltimatE ZJ Grand Cherokee Forum 9 12-15-2007 10:42 PM
neutral safety switch joeyschribar ZJ Grand Cherokee Forum 3 04-02-2006 07:19 PM
