******* that needs help with suspension - JeepForum.com
post #1 of 7 Old 04-07-2009, 09:03 PM Thread Starter
zach36532
im plaining on putting on a 4" rough country lift and putting 2" spacers on to make a total of 6" and i was wondering if when i put all that on will i have to change out my driveshaft or make any other mods???.... any feed back would help. thank you
zach36532 is offline
post #2 of 7 Old 04-07-2009, 09:05 PM
gatorayde
Add in an extra 3" spacer too for 9" total (not...)
If you are going to 6" total, you need everything for 6" total. You don't seem very well educated on lifting jeeps so I would not suggest jumping head first into such a high lift height. Do the research and do it right
gatorayde is offline
post #3 of 7 Old 04-07-2009, 09:51 PM
the88thpianoman
2003 WJ
You would need to change your driveshafts, control arms,front and rear track bars, shocks, front and rear sway bar links, and something else that I might be forgetting. Oh yeah, while you're at it, go ahead and swap out the springs for 6" springs, and sell the spacers.
Basically, if you want to lift 6", you need a 6" kit. A 4" kit will work only for 4" of lift, not 6". If you want a 6" kit, you need to be prepared to shell out between $2500 and $3000, and that's before you get wheels and tires. And if you fit the maximum size tire under a 6" lift, you will not want, you will need to regear, and if you have the D35 in the back, you'll need to junk that and swap in at least an 8.8.
Now, I don't mean to come off as a jerk or anything, it's just that we get this exact question or some slight variation of it nearly every day. I understand that it's easy to think big and get in over your head and budget very quickly. It's good to start off with a smaller lift like the IRO front to rear swap, or the rough country kit you're considering. I also highly recommend installing the lift yourself. It isn't that difficult, and you will learn tons about your Jeep's suspension and how everything works, which will in turn help you understand why you need all the crap I mentioned for an extra two inches of lift.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #4 of 7 Old 04-07-2009, 10:22 PM
RRAM
Well I think you been told. But I would believe what they said. I put a 2 in spring lift with new shocks and it changes enough stuff that keeps a guy busy. There is so much info on lifts here that its overwelming. But after reading and reading I figure that 3.5 is pretty safe kit (wish I had done that) After that you are wanting a lot of parts and a lot cash spent. This forum is very helpful and very full of info do a search on lifts and your going to be reading for a few days. Good luck and hope to see pics of your jeep build.
Reg
93 ZJ 5.2 auto
2" bds lift and shocks, 31" tires
04 GC Limited 4.7 Wife drives this one
RRAM is offline
post #5 of 7 Old 04-08-2009, 08:42 AM
coupleofjeeps
6" is a much bigger project than 4"
BUT once you're at 4" its easier to move up if you piece together the right components to begin with i.e. sway bar links and discos, adj. track bars... plus when you know what you're doing after doing it a time or two moving up the progression, you will be able to handle it better especially when it comes to troubleshooting a problem or knowing what to repair...
my says work your way up, start 4
coupleofjeeps is offline
post #6 of 7 Old 04-08-2009, 08:48 AM
DothanJeep
Just do a body lift!
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #7 of 7 Old 04-08-2009, 10:09 AM Thread Starter
zach36532
where can i find the a driveshaft i need?
BDS Suspension bwscheff45 ZJ Grand Cherokee Forum 6 10-18-2009 11:49 PM
suspension Drenyce311 ZJ Grand Cherokee Forum 2 02-23-2009 11:07 PM
What Suspension? IRPerformance ZJ Grand Cherokee Forum 16 04-13-2008 06:45 PM
Old Man Emu Suspension gcjeeper ZJ Grand Cherokee Forum 2 09-03-2005 11:48 AM
BDS suspension Nevin Bretz ZJ Grand Cherokee Forum 1 03-27-2003 06:41 PM
