Need a ZJ, have some Q's... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Need a ZJ, have some Q's...
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 10-01-2003, 01:23 AM   #1
iNeedaZJ
Ok, I know this question has probably been answered a million times but I ran a search and didn't find exactly what I was looking for. So, I don't have a ton of money to spend and I am looking at a 93 or 94 Grand Cherokee. My question is between the I6 or the V8. My biggest concern is with the reliability of the V8 especially in the early stages of the ZJ. I really want the power, but how many miles can you typically get out of the V8? Also I plan to do a mild lift with 31's, will the I6 handle these fine or should I step up to the V8?
Thanks for the help!
Geoff "The Newbie Here"
iNeedaZJ is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 06:18 AM   #2
10achik
I ate what?
10achik's Avatar
Your right this has been answered a million times, but for what it's worth, I had the I6 and didn't like it. I went up to the V8 and have never regreted it. I can't personally vouch for the 93 to 94 time frame but mine runs like a champ...
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 09:09 AM   #3
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Get the V8 you will appreciate the horsepower.
Hunter
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 09:37 AM   #4
iNeedaZJ
I was kind of leaning towards the V8 but have also heard that it's not as reliable. Anybody know how long they generally last? I'm looking for a 93 or 94 since thats what I can afford. Anybody with experience from these years? Thanks
Unread 10-01-2003, 01:15 PM   #5
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I haven't had problems with the reliability of my v8 after 10 years.
Hunter
08 Z71 Suburban
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Unread 10-01-2003, 02:02 PM   #6
Harald
Have 96 GC V8 5.2L run 110 000 miles. Nothing done with the engine exept normal service like oil changes etc. My experience from 25 years with engines is that the V8 will be the last part to cave in on this car. Guess it will last at least 250 000 miles. Engines are normaly not the problem. It's the rest of the car falling appart around it....
Harald is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 03:28 PM   #7
iNeedaZJ
Cool, thanks guys. That's what I was hoping to hear
Unread 10-01-2003, 04:51 PM   #8
iroc22
I have a 93 ZJ with the V8.
So far have had no problems with the ZJ except I grenaded my CV axle. No biggie.
As for the V8, how does 160k miles with no leaks and doesnt burn a drop of oil sound?
2002 Jeep TJ Sport 4.0L Patriot Blue/Black Hardtop Dana 44
1996 Jeep ZJ Orvis fully loaded
1995 Pontiac Trans Am 5.7L - 6 speed
1928 Ford Model A - Street Rod Project
iroc22 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 05:46 PM   #9
iNeedaZJ
That sounds good to me You'd be a good person to ask about gas mileage with the 31s and all. That's what my plans are, so how bad is it?
Unread 10-01-2003, 07:22 PM   #10
DrewT
I have an I6 in my '96 ZJ, and I can say it has enough power for a daily driver, but it would be nice to have more power sometimes. When you push the pedal to the floor, it just dosen't feel like it is going that fast. I just ordered the K&N FIPK, and that should help. I wish I could find a way to adapt the heads and intake system from Chrisler's 3.5L DOHC I6. Intake splits off and goes to two throtle bodies, then one side of the intake goes to every other cylinder. Had lots of power...
Get the V8, you will probally like it...
DrewT is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 08:25 PM   #11
JAURS
Like most others said, I would go with the V8. The 318 which is the engine used in the ZJ's rarely has any mechanical problems. I have 143K miles on my 96 and run 31 inch tires. I have driven across the country numerous times, gone off-roading, and it has never failed me. Ask most people what they think of the 318, and they'll say it'll run at least 250-300K miles if properly maintained. The I6 is a good engine, but lacks the power to run a lift and larger tires in my opinion. Good luck with your choice.
JAURS is offline   Reply With Quote Quick reply to this message
Unread 10-01-2003, 11:32 PM   #12
iroc22
On the freeway I can get 20-22mpg and in the city I get anywhere from 9mpg to 14mpg. Usually I'm somewhere in the middle depending on how hard on the gas I am. There was a decent improvement on the freeway from the 235/75R15's when I swapped to 31's. Reduced the effective gear ratio so the mileage improved by about 2mpg.
Unread 10-02-2003, 12:26 AM   #13
iNeedaZJ
Thanks guys. You've been a lot of help and I'm really leaning towards the V8 since all of you have had good luck with them.
