Need your help: Removing Calipers from Rotors on 1999 Grand Cherokee 4x4, front - JeepForum.com
post #1 of 5 Old 06-29-2004, 07:13 PM Thread Starter
cjdietzman
Hello! Thanks for checking out my thread.
Anyway, I am preparing to replace my front rotors and pads on my 1999 Grand Cherokee Laredo 4x4, and I pulled a wheel off today to take a look.
QUESTION: What is the best way to get the calipers off of the rotor? Should I remove the 2 allen screws that hold the caliper to the brackets, or the two nuts that hold the caliper brackets to the truck...OR both? I loosened up the 2 allen screws, and that seemed to do nothing...the caliper would not come off...easily anyway.
Does my question make sense? Obviously, I do not do this kind of work every day. Your advice would be appreciated. THANKS!!!
cjdietzman is offline
post #2 of 5 Old 06-30-2004, 04:53 PM
ercrmr
Taking off the allen bolts is all that's needed to take off the caliper. If your going to take off the rotor (to resurface or replace) then take off the caliper bracket after taking off the caliper. Hope this helps
ercrmr is offline
post #3 of 5 Old 07-01-2004, 07:00 AM Thread Starter
cjdietzman
Thanks for the reply. When I loosened the 2 allen bolts the other night, the caliper still seemed "stuck" to the rotor. Should I pry it of with a screwdriver?
post #4 of 5 Old 07-01-2004, 09:05 AM
97RedBird
2009 MK Compass
You will need to compress the caliper piston with something to get the pressure off the rotor(watch that the brake fluid doesn't overflow out of the master cylinder resevoir) I sometimes use a screw driver and/or a C-clamp., but be careful not to scratch the rotor (if you are reusing it).
97RedBird is offline
post #5 of 5 Old 07-01-2004, 10:24 AM Thread Starter
cjdietzman
Thanks RedBird!
Calipers Will Not Fit Over New Rotors - 1999 WJ netmaxweb ZJ Grand Cherokee Forum 18 10-05-2009 11:21 PM
1999 Grand Cherokee Laredo Front Brakes kevynrenner ZJ Grand Cherokee Forum 5 03-21-2008 04:56 PM
Removing front corner light 1998 Grand Cherokee rjacb ZJ Grand Cherokee Forum 3 09-11-2005 01:33 PM
Class Action Suit/DEFECTIVE ROTORS/Grand Jeep Owners 1999-2002 KevinRichard ZJ Grand Cherokee Forum 18 08-10-2004 10:44 AM
Rubbing Noise in Front-end when I hit bumps with my 1999 Jeep Grand Cherokee Laredo cjdietzman WJ Grand Cherokee Forum 9 02-21-2003 08:51 AM
